gcc compiler for nios2
I am looking for a nios2-elf-gcc compiler that runs under linux. I have a working nios-elf-gcc compiler for NIOS1 but can't find the NIOS2 version anywhere.
Jelle
The Nios II toolchain can be rebuilt under Linux using the source code found on the Nios II Embedded Processor CD.
The source code should be installed onto your windows machine. I tarred and bzipped it, and then transferred it to my Linux machine.
Word of warning... the toolchain is littered with CRLF's that really cause problems with the configure scripts and Makefiles. Any problems you might have are quite likely due to CRLF's. You may want to try running the source tree through a "dos2unix" type utility. I used "flip" to fix up the tree.
I used the following environment variables while following the instructions below:
target = nios2-elf prefix = /home/kenw/work/r6200 scratch = /home/kenw/tmp
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Building/Installing binutils
$ mkdir -p $scratch/build/binutils
$ cd $scratch/build/binutils
$ $scratch/src/binutils/configure
--target=$target
--prefix=$prefix
-v 2>&1 | tee configure.out
$ make -w all install 2>&1 | tee make.out
$ export PATH=$prefix/bin:$PATH
Building/Installing gcc
$ mkdir -p $scratch/build/gcc
$ cd $scratch/build/gcc
$ $scratch/src/gcc/configure
--target=$target
--prefix=$prefix
--with-gnu-as
--with-gnu-ld
--with-newlib
$ make -w all-gcc install-gcc
LANGUAGES="c c++" 2>&1 | tee make.out
Building/Installing newlib
$ mkdir -p $scratch/build/newlib
$ cd $scratch/build/newlib
$ $scratch/src/newlib/configure
--target=$target
--prefix=$prefix
2>&1 | tee make.out
$ cd $scratch/src/newlib/newlib
$ cp configure.host.smallc configure.host
$ make 2>&1 | tee make.out
$ make install[/b]
--- Quote End ---
Good luck!
If you don&#39;t need linux toolchain support this very moment I suggest waiting a few weeks -- our next (Nios II 1.1) release will give you everything you need.
Thanks for your reactions. I&#39;ve found the source files. It was an extra option during the installation of the NIOSII IDE.
I compiled the source code and now I have a working compiler.
Jelle
