12452 Discussions
>30% CPU load increase with USB FLash plugged in (lots of SOF interrupts)
I have a Cyclone V (kernel 4.1.22-ltsi-rt) with an USB3320 transceiver connected to USB1. There is a USB2422 HUB (2 port) connected to USB3320. One of the ports is connected to a 4 port CY7C65630.
CV <--> USB3320 <--> USB2422 <-port 2-> CY7C65630 <-4-ports-> (unused) | <-port 1-> USB Flash
When I plug-in a USB flash to USB2422 (port 1), CPU load increases by ~30% (two IRQ 36 handlers). I've found out that this is mainly due to the Start-of-Frame (SOF) interrupts being triggered every 125us. I have also enabled CONFIG_USB_DWC2_TRACK_MISSED_SOFS in the kernel and I get a dump of first 1000 missed SOFS very quickly.
Except from the above, the USB Flash is mounted and can be used without a problem.
My question is, is the CPU load normal or have I configured something incorrectly?
usbphy0: usbphy@0 {
# phy-cells = <0>;
compatible = "usb-nop-xceiv";
status = "okay";
usb0: usb@ffb00000 {
compatible = "snps,dwc2";
reg = <0xffb00000 0xffff>;
interrupts = <0 125 4>;
clocks = <&usb_mp_clk>;
clock-names = "otg";
phys = <&usbphy0>;
phy-names = "usb2-phy";
status = "disabled";
usb1: usb@ffb40000 {
reg = <0xffb40000 0xffff>;
interrupts = <0 128 4>;
phys = <&usbphy0>;
BR mrkozmic
Ventura
Dear Mr. @mrkozmic
Have you been able to fix this issue?
Like you, I'm currently testing a Cyclone V Board [1] with Linux Kernel 4.1.22 with RT Patch.
My USB Devices are a little different:
CV <--> USB3320 <--> SMSC_LAN9500
I don't have a hub connected to the USB-PHY. I am directly connecting an USB to Ethernet device.
I disabled the OTG, so that I only have two IRQs instead of the default 3 IRQs assigned by the dwc2 driver (USB driver).
I am currently watching around 20% CPU usage, but when I had the 3 interrupts, I also had 30% CPU usage exactly like you reported.
The number of interrupts observed on /proc/interrupts for IRQ45 (all USB interrupts) are also very very high too, around 7000 interrupts per second!
For debug, I also tested the non-RT version and this issue does not occur.
Ventura
[1] - https://rocketboards.org/foswiki/Documentation/ArrowSoCKitEvaluationBoard
