having trouble with interrupt
Hello everyone ,
I'm try for a very long time to do a simple interrupt with nios ii.
this is my problem:
i have button in sratix ii dev kit and all i want to do in nios is just to turn on led (with interrupt) when the button is pressed.
i defined rising_edge and all the others in sopc and i checked that the button is connected to the sopc module in quartus.
everything passed the compile but when i run the debug the program ignore my clicks on the button and do nothing.
this is my program:
the program ignore my clicks and doesn't get to here :\
void led_interrupt()
//turn on led//
//Delay//
void main()
alt_irq_registerr(button_IRQ, led_interrupt );
//turn off led//
while(1); // waiting for interrupt;
I hope somebody can help me.
sorry for my bad english:)
thanks you(:
Add these before alt_irq_register:
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_IRQ, <irq_bit_mask>); // enable irq
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(button_IRQ, <irq_bit_mask>); // clear irq
You also need to clear the edge capture bit in irq handler function, otherwise the irq will keep on retriggering.
Also make sure of these points:
- in qsys/sopc button pio must be defined with interrupt capability enabled
- the button pio is correctly routed to fpga pin and pio is working: begin with polling the pio in while loop to test this point.
Could you elaborate on the definition of "irq_bit_mask"?
In SOPC builder, my PIO IRQ (width = 1 bit) is on IRQ line 9.
Does this mean my "irq_bit_mask" is bit 9?
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_base_address,1); // enable irq
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(button_base_address, 1); // clear irq
Infact you are using PIO bit 0, then mask = 1.
For clarity: if you had a 8 bit wide PIO and you connected the button to pio_input[6], then you'd had irq_bit_mask=0x40
IRQ line nr is involved only in alt_irq_register() call.
