Hi All,
Can anyone find the "hello_world_multi.c" file which was used in altera tutorial; "Creating Multiprocessor Nios II Systems Tutorial" May 2006, Version 6.0. ? Herewith I have attached tutorial as well. Thank YouLink Copied
I think that tutorial has been updated and is here:
https://www.altera.com/literature/tt/tt_nios2_multiprocessor_tutorial.pdf And the accompanying code is here: https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios... The example is a bit different now but should illustrate the same concepts.- Mark as New
Thank you for your reply.
Yeah, I noticed; it has been updated. But they are different. In the older version, they used a simple multiprocessor system and in the newer one hierarchical system. Can we get the older version? Thank You
