hi:
when I download .elf to FPGA ,but faileded , !SESSION 2011-06-13 11:27:44.687 ----------------------------------------------- !!ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:04:09.546 !MESSAGE The expected CPU name does not match the selected target CPU name. !ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:04:09.546 !MESSAGE The expected Stdout device name does not match the selected target byte stream device name. !ENTRY com.altera.sbtgui.launch 1 0 2011-06-13 12:04:12.000 !MESSAGE Executing: [C:\WINDOWS\system32\cmd.exe, /C, C:/altera/10.1/quartus\bin\cygwin\bin\bash.exe, -c, nios2-download '--cable=USB-Blaster on localhost [USB-0]' --device=1 --instance=0 --sidp=0x25018 --id=0x0 --timestamp=1307935183 /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf] !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:04:20.250 !MESSAGE Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, --sidp=0x25018, --id=0x0, --timestamp=1307935183, /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf] return code: 4, 'other error' !ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:07:00.796 !MESSAGE Obtaining system ID information for selected processor !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:00.796 !MESSAGE SOPC design not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:00.796 !MESSAGE CPU module not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:00.796 !MESSAGE The SOPC design does not contain a CPU of a supported architecture. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:00.796 !MESSAGE CPU architecture type not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:00.796 !MESSAGE CPU master group not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.187 !MESSAGE CPU architecture type not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.187 !MESSAGE CPU master group not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.750 !MESSAGE SOPC design not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.750 !MESSAGE CPU module not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.750 !MESSAGE The SOPC design does not contain a CPU of a supported architecture. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.750 !MESSAGE CPU architecture type not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:04.750 !MESSAGE CPU master group not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.546 !MESSAGE SOPC design not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.578 !MESSAGE CPU module not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.609 !MESSAGE The SOPC design does not contain a CPU of a supported architecture. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.640 !MESSAGE CPU architecture type not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:13.687 !MESSAGE CPU master group not set. !ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:07:13.703 !MESSAGE Obtaining system ID information for selected processor !ENTRY com.altera.sbtgui.launch 2 0 2011-06-13 12:07:14.218 !MESSAGE Obtaining system ID information for selected processor !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:14.265 !MESSAGE SOPC design not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:14.265 !MESSAGE CPU module not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:14.265 !MESSAGE The SOPC design does not contain a CPU of a supported architecture. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:14.265 !MESSAGE CPU architecture type not set. !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:14.265 !MESSAGE CPU master group not set. !ENTRY com.altera.sbtgui.launch 1 0 2011-06-13 12:07:16.343 !MESSAGE Executing: [C:\WINDOWS\system32\cmd.exe, /C, C:/altera/10.1/quartus\bin\cygwin\bin\bash.exe, -c, nios2-download '--cable=USB-Blaster on localhost [USB-0]' --device=1 --instance=0 --accept-bad-sysid --sidp=0x25018 /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf] !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:22.937 !MESSAGE Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, --accept-bad-sysid, --sidp=0x25018, /cygdrive/d/10.1/apical_top_sq/apical_top_demo_isp_youjing/pri_apical/software/fsysid/fsysid.elf] return code: 4, 'other error' !ENTRY com.altera.sbtgui.launch 4 0 2011-06-13 12:07:22.937 !MESSAGE Downloading ELF Process failed I can be sure ,my sysid is right and .sopcinfo is rightLink Copied
Did you figure it out? I am having the same issue...
