I'm trying to make uClinux's zImage by executing command "make" after i have done the "make menuconfig" and "make vendor_hwselect" successfully, but the process always executing the some code, the following code are part of it:
2 DGRAM 14288
unix 2 DGRAM 14381
unix 3 DGRAM 9624
unix 3 DGRAM 9623
unix 2 DGRAM 9398
unix 2 DGRAM 9397
zip error: Nothing to do! (6/ddp.zip)Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 26 DGRAM 1796 /dev/log
unix 2 DGRAM 1805 /run/systemd/shutdownd
unix 2 DGRAM 1861 @/org/kernel/udev/udevd
unix 2 DGRAM 8564 /run/systemd/notify
unix 3 STREAM CONNECTED 135793 /home/hanxu/.pulse/03150a200ccbe5c4977b361c00000014-runtime/native
unix 3 STREAM CONNECTED 136789
unix 3 STREAM CONNECTED 134120 @/tmp/dbus-2sNK3v4L
unix 3 STREAM CONNECTED 134119
unix 3 STREAM CONNECTED 134636 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 134097
unix 3 STREAM CONNECTED 134083 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 134082
unix 3 STREAM CONNECTED 134080 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 134594
unix 3 STREAM CONNECTED 134593 @/tmp/.ICE-unix/1632
unix 3 STREAM CONNECTED 134592
unix 3 STREAM CONNECTED 134071 @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 134549
unix 3 STREAM CONNECTED 111122 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 112010
unix 3 STREAM CONNECTED 111116 /tmp/orbit-hanxu/linc-12f2-0-2a10c26aec2c
unix 3 STREAM CONNECTED 112009
unix 3 STREAM CONNECTED 112008 /tmp/orbit-hanxu/linc-6b4-0-61155ec35924a
unix 3 STREAM CONNECTED 111114
unix 3 STREAM CONNECTED 111095 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 111997
unix 3 STREAM CONNECTED 111090 @/tmp/dbus-2sNK3v4L
unix 3 STREAM CONNECTED 111993
unix 3 STREAM CONNECTED 111083
unix 3 STREAM CONNECTED 111082
unix 3 STREAM CONNECTED 111080 @/tmp/.ICE-unix/1632
unix 3 STREAM CONNECTED 111970
unix 3 STREAM CONNECTED 111956 @/tmp/.X11-unix/X0
unix 3 STREAM CONNECTED 111955
unix 3 STREAM CONNECTED 84577 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 84576
unix 3 STREAM CONNECTED 32551 @/dbus-vfs-daemon/socket-1VOtJCXs
unix 3 STREAM CONNECTED 32550
unix 3 STREAM CONNECTED 32552 @/dbus-vfs-daemon/socket-1of8MTTR
unix 3 STREAM CONNECTED 32549
unix 3 STREAM CONNECTED 32542 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 32541
unix 3 STREAM CONNECTED 32425 @/tmp/dbus-2sNK3v4L
unix 3 STREAM CONNECTED 32424
unix 3 STREAM CONNECTED 32423 @/dbus-vfs-daemon/socket-VxPLb4zk
unix 3 STREAM CONNECTED 32422
unix 3 STREAM CONNECTED 32421 @/dbus-vfs-daemon/socket-DMo2AJtV
unix 3 STREAM CONNECTED 32420
unix 3 STREAM CONNECTED 31633 @/dbus-vfs-daemon/socket-FMBnlpZE
unix 3 STREAM CONNECTED 31632
unix 3 STREAM CONNECTED 31634 @/dbus-vfs-daemon/socket-0kWNSiNm
unix 3 STREAM CONNECTED 31631
unix 3 STREAM CONNECTED 31625 @/tmp/dbus-accCQ7gn3g
unix 3 STREAM CONNECTED 32412
ps:I use the .ptf file provided in wiki and in "make menuconfig" I choose Default all Settings. can anybody help me? thanks in advance.
That text looks like the output from 'netstat'.
I have known the answer. the zImage must be make under linux's file system.
