Altera FPGA device is named by LEs (logic element) i.e.: ep1c6 (6 means 6k LEs)
1. what's the LC(logic cell) ? Does it have some relationship whith LE? 2. LE , LC contain how many gates normallyLink Copied
--- Quote Start --- originally posted by mountain8848@Feb 7 2006, 07:55 AM altera fpga device is named by les (logic element) i.e.: ep1c6 (6 means 6k les)
1. what's the lc(logic cell) ? does it have some relationship whith le?
2. le , lc contain how many gates normally
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12606)
--- quote end ---
--- Quote End --- Hi Mountain8848, Long history in what is an LC(logic cell), LE (Logic Element) and MC(Macrocell). The best answers are found here in Altera's Glossary of terms: http://www.altera.com/literature/glossary/glossary.pdf (http://www.altera.com/literature/glossary/glossary.pdf) The Logic Cell is a generic term to mean either an LE or MC depending on the architecture. LE are Look-up-table (LUT) based cells in the SRAM devices (FLEX, APEX, Stratix, Cyclone etc...) and MC are p-term based cells in the MAX families. Here is an interesting press release: http://www.altera.com/corporate/news_room/...easurement.html (http://www.altera.com/corporate/news_room/releases/releases_archive/2001/products/pr-logic_measurement.html) As for how many gates in an LE? You would have to guess how much logic you can effectively pack into a 4 input LUT along with the DFF. Regards, -ATJ
