12596 Discussions
.hex file generate for Nios-II C code
I am using Quartus-II Version 9.1sp2 and i am also using Nios-II IDE Version 9.1. I have a Custom board with Cyclone-I FPGA EP1C12Q240C8N. I made Nios-II Base project using SOPC Builder and write a program for blinking LED in Nios-II IDE.
I am not using Flash programmer for loading Nios-II Program. I made .hex file of my C program from adding "mem_init_generate" in make target>>Build of Nios-II Project and add in Quartus-II. Problem is, after adding .hex file in Quartus-II, i update Memory Initialization file and reassemble the Quartus project, but then also my program not run. So please suggest solution for this problem.
Below is message of Nios-II IDE after Build project.
Post-processing to create mem_init/Program_Memory.hex...
elf2hex STQFP.elf 0x00004000 0x00007fff --width=32
--create-lanes=0 mem_init/Program_Memory.hex
Post-processing to create mem_init/hdl_sim/Program_Memory.dat...
elf2dat --infile=STQFP.elf --outfile=mem_init/hdl_sim/Program_Memory.dat
--base=0x00004000 --end=0x00007fff --width=32
--create-lanes=0
Post-processing to create mem_init/hdl_sim/Program_Memory.sym...
nios2-elf-nm -n STQFP.elf > mem_init/hdl_sim/Program_Memory.sym
Nandish Jasani.
try to append "--record=4" after "elf2hex STQFP.elf 0x00004000 0x00007fff --width=32" before the backslash (in your projects mem_init.mk file).
I have to do this for years, now. I don't know how other people get a working hex file out of the automatic Nios II build process. Once i regenerate my BSP, I have to add this line, again, because it overwrites the mem_init.mk file.
I'm not a "build process"- / make- /toolchain- /whatever-guru, so I was not able to find an automatic solution for this issue. I just take it as a little drawback of the tools which I found my own workaround for.
Please report, if it also solved you problem.
Maik
Thanks Maik,
I successfully appended “--record=4” in my make file, still I am facing the same issue.
What file should I add to Quartus-II Projects after make target (I have added .mk and .hex in Quartus-II Project according one of the altera forum threads)?
We have another custom board with Cyclone-IV and we are using Quartus-II Version 13.0 for different project. In Nios-II, make target generates .qip file which we added to Quartus project and the project works as required. So we tried similarly for Quartus-II Version 9.1sp2.
Below is the build message.
elf2hex STQFP.elf 0x00000000 0x00003fff --width=32 --record=4
--base=0x00000000 --end=0x00003fff --width=32
--create-lanes=0
Nandish Jasani
starting with Quartus 9.1 SP2, I got these hex file generation generation issues. Though I do not exactly understand what exactly your problem is.
What I have to do with this very version of the build tools is the following:
I generate a BSP project from my sopcinfo file. After that I generate a firmware project which refers to the just created BSP. All this I perform with the "Nios II Software Build Tools for Eclipse" Project Wizzard.
After that I do have to make two changes in the automatically generated make files.
The one is the change I posted above. The other is in the Makefile of the BSP in the line "CREATE_ELF_DERIVED_FILES := 1" which I have to set to one as shown here. This is responsible for creating the hex file at all.
The --record=4 flag is responsible for the layout or alignment of the hex file.
If I follow these steps with the exact tools version you mentioned, then I can work with it succesfully for years, now.
Still, I'm intereseted in suggestions leading to a more convinient way to handle this hex file creation because as I said, once you run the BSP editor, you have to reset those settings in order to get your hex file.
I hope this helps.
Maik
As additional info, here is one of my hex creation build message that sucessfully creates a usabel hex file (one for onchip ram and one for onchip rom which contains the program data).
Post-processing to create mem_init/onchip_ram.hex...
bash -c 'elf2hex e_fpga_0100_firmware.elf 0x00424000 0x00427fff --width=32 --record=4
--little-endian-mem --create-lanes=0 mem_init/onchip_ram.hex'
`mem_init/onchip_ram.hex' -> `../../onchip_ram.hex'
Post-processing to create mem_init/onchip_rom.hex...
bash -c 'elf2hex e_fpga_0100_firmware.elf 0x00410000 0x0041c7ff --width=32 --record=4
--little-endian-mem --create-lanes=0 mem_init/onchip_rom.hex'
`mem_init/onchip_rom.hex' -> `../../onchip_rom.hex'
Maik
没有看懂是怎么弄的,有相应的使用文档吗?
