this thread continous my problems from http://www.alteraforum.com/forum/showthread.php?t=28699
... Hiho! After a long time - its me again! So ... now i switched back to windows XP! Matlab2009b, Quartus11. Now i can create a java object after the explaination from wombat of the 6th june. so far so good. next step - next problem. Now i get the same error: http://www.alteraforum.com/forum/showthread.php?t=28931 Error : Could not initialize class com.altera.systemconsole.internal.plugin.jtag.aji i also thougth about wombats answer: "What I suspect happened here is that your path had somehow made windows load the wrong versions of the native library - one which is not compatible with the Java - or that that DLL found the wrong version of a dll it depends on. (The windows DLL loading rules are byzantine, and Java doesn't really provide any good ways to override them)" i donot really understand what you mean. i installed the actual jre6 on windows xp. ------------------------------------------------------------------------------------- MATLAB Version 7.9.0.529 (R2009b) MATLAB License Number: XXXXXX Operating System: Microsoft Windows XP Version 5.1 (Build 2600: Service Pack 3) Java VM Version: Java 1.6.0_12-b04 with Sun Microsystems Inc. Java HotSpot(TM) Client VM mixed mode ------------------------------------------------------------------------------------- MATLAB Version 7.9 (R2009b) Simulink Version 7.4 (R2009b) Communications Toolbox Version 4.4 (R2009b) Signal Processing Toolbox Version 6.12 (R2009b) ------------------------------------------------------------------------------------- i am very interested in the step that mazel did to solve his problems. i am also thinking about configuration problems of my niosII system. mhhh ... ?? greetsLink Copied
