Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
12500 Discussions
how set SDRAM controller for samsum K4S281632F
i have a board with EP2C8Q208 and a SDRAM for run NIOS2
the SDRAM chip is K4S281632F 8MX16, but in the SDRAM controller dont show that device
Can you help how set the SDRAM controller to that SDRAM ?
https://www.alteraforum.com/forum/attachment.php?attachmentid=5130
https://www.alteraforum.com/forum/attachment.php?attachmentid=5131
https://www.alteraforum.com/forum/attachment.php?attachmentid=5132
The settings in the first window (Memory Profile) look correct (16 Bits, 1 Chip Select, 4 Banks, 12 Rows, 9 Columns)
For the second window I would put:
CAS latency cycles: 3
Init refresh cycles: 2
Refresh command every: 7.8125us (needs to refresh 8192 times in 64ms)
Delay after power up: 200us (not given in the datasheet, but should be in the order of several 100s of us)
t_rfc: 70ns
t_rp: 20ns
t_rcd: 20ns
t_ac: 5.5ns
t_wr: 15
t_rfc, t_ac and t_wr are guesses on my behalf, but it should work as most SDRAM chips of these specs follow the same parameters. If it doesn't work try increasing the values of those three.
my problem was the clock of SDRAM, this need some delay from main clock
i tested with -3ns using Avalon ALTPLL for CycloneII, and EUREKA that work
thanks a lot
https://www.alteraforum.com/forum/attachment.php?attachmentid=5133
thanks a lot chnaideur
