Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
how to add ifconfig command
Hi There,
I got my first uClinux built and worked on a Nios II Stratix Evaluation board by following Linux Quick Start Guide. But there is no ifconfig command, or "ifconfig: not found". It must be the configuration issue.
Thanks for any info and help.
Ltao
Highlighted
Re: how to add ifconfig command
the ifconfig command is "inside" busybox. You can type# busybox ifconfig
or make a symlink# ln -s busybox ifconfig
So you can use ifconfig directly.
I think you forgot to include ifconfig when creating a new filesystem-project.
Highlighted
Thank very much. Add busybox in the filesystem and works.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
