NiosĀ® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and NiosĀ® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
12469 Discussions
how to convert .axf file to .bin file? **the bare-metal application, Cyclone V , SD-card**
KBill3
Hello all šŸ˜„.
To run the bare-metal application on Altera Cyclone V using HPS from SD-card., some steps need to be done, i have a problem in this step:
Create simple app in DS-5, compile it and obtain test.axf then convert it to test.bin using fromelf command and then convert it in test.img with mkimage tool.
how and where should i use this fromelf command?
Thanks in advance.
PHJ
ā€‹I just include it in the post-build steps (under Build Steps tab in the C/C++ Build Settings):
fromelf --bincombined ${ProjName}.axf --output=${ProjName}.bin
KBill3
thank you very much for your answer, it is very nice solution, what did you then to convert .bin to .img?
Thanks in Advance.
LG, Billel
PHJ
ā€‹I issue the mkimage command from outside the DS-5 tool as a manual post-build step.
I do this from a SoC EDS command shell.
If someone knows the way to get this step completed from the DS-5 tool I'd be happy to hear about it !
