Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
how to erase my flash
i can't download my program to my flash! someone told me ,the flash needs to be erased using a program wrote by user! But how to write the program ? is there any other way to erase my flash!
thanks[B]
Highlighted
Re: how to erase my flash
Hi icesword,
Use nios2-flash-programmer
If you want to completely erase your flash use the --erase option.
Try: nios2-flash-programmer --help for a description of the options.
--Scott
Highlighted
I am a beginner.I don't know where and how to use the instruction you said.whether you can give some details?
Highlighted
Hi icesword,
> I am a beginner.
Welcome! :-)
The documentation for flash programming can provide you with many
details ... you should read this first. Then, if you have any questions you
will be able to get more answers on this forum.
--Scott
Highlighted
Ooops ... sorry, the document is:
Nios II Flash Programmer User Guide (ug_nios2_flash_programmer.pdf in the
altera/kits/nios2/documentation directory).
--Scott
Highlighted
thanks!
