is there somebody know how to modify the ptf file?i find the sram on my dsp development board is IDT71V3578,but it can't be found in the SOPC BUILDER,so i want to chang the sram's ptf file the SOPC BUILDER supportBany suggestion is gratitude!
So do I!!
I have met the same problem as you, and I have tried to modify the ptf document, but I failed. And now I am trying to write a interface which can change the asynchronous timing to synchronous timing, and then from the Nios avalon bus, the SSRAM works as ASRAM. But I still think that to modify the ptf is the best method to make it works. Can anyone tell we how to do it?? thinks!!
