12590 Discussions
how to pass a pointer or array name to the interrupt function?
hi
i register a interrupt in nios, and it works well
alt_ic_isr_register (NIOS_FT245_INTERFACE_0_IRQ_INTERRUPT_CONTROLLER_ID,
NIOS_FT245_INTERFACE_0_IRQ,
ft245_interrupt,
NULL,
NULL);
i want to pass a pointer or array name to the interrupt function ft245_interrupt, how can i do it?
thanks!
The documentation for the HAL functions are in altera_hal_api.pdf. Whatever you give to the context arg will be passed to your isr function. In your code this is the first NULL.
hi, i tried and it works!
this is the code:
void ft245_interrupt(alt_u32 precision_data[500])
int main()
alt_u32 i=0;
alt_u32 precision_data_1[500]={0};
i=alt_irq_enabled();
ft245_interrupt,
precision_data_1,
NULL);
but the eclipse give me a warning
Description Resource Path Location Type
passing argument 3 of 'alt_ic_isr_register' from incompatible pointer type hello_world.c /project3 line 99 C/C++ Problem
The warning is because the type of your ISR function argument doesn't match what alt_ic_isr_register expects which is (void *). Try using (void *)precision_data_1 for that argument.
Edit: wrong argument.
