12604 Discussions
how to uninstall Nios II eclipse
dsun01
New Contributor III
Dear Support,
I have trouble to run the Nios II eclipse properly, you can see the problem detail here.
Re: Template is empty in the Nios II application and BSP from Template - Intel Communities
I don't know why I didn't get any response after I posed it there.
I keep searching on the Forum, I notice that there is a very old post may give me some hint,
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/Problems-with-creating-a-Nios-II-Application-and-BSP-from/td-p/64196
I quoted here.
After uninstalling Nios II EDS, I indeed found some Eclipse files and folders remaining. I manually deleted them, then installed back Nios II EDS and I finally got the "nios ii application and bsp from template" back :). That probably was a problem of corrupted Eclipse.
How to uninstall the Nios II EDS? it is not shown in the windows "uninstall or change a program" list.
please give an uninstall procedure detail or a link to it.
thank you very much.
David
EBERLAZARE_I_Intel
We recommend that you uninstall everything completely, and reinstall everything again completely. As there might be unexpected behavior if the installation is not been done correctly. If you don't see it in the control panel in the uninstall section, I believe it has been removed.
EBERLAZARE_I_Intel
dsun01
New Contributor III
Thank you very much, I will follow your instruction.
