hello ,
who can tell me how to use cs8900 in niosii device drivers? it is not HAL , do i need build a HAL for it? thanks!Link Copied
Hello maoguohua2002,
Currently there is no HAL device driver available for the Nios II. You can use the legacy SDK driver. But then you have to use the legacy SDK for all other components too. Another possibility is to write your own HAL driver. At the moment I’m doing this for the DM9000 from Davicom. But this will take some time. Bye, niosIIuser- Mark as New
hello niosIIuser,
The Altera gives the document is not enough detailed, do you have any document about how to use the legacy SDK driver or how to write my own HAL driver detailed. Thanks!- Mark as New
I’m sorry I don’t have a detailed description for writing a device driver. Bye, niosIIuser
