I have add a pin namely “enb” on nios processor as display in attached print-screen, every time this pin got high pulse. my IORD_..function read this pulse and start doing my further job.
i have seen through oscilloscope that enb pulse is keep coming but my software routine could not read this pin ...it always says “enb = 0” Rate of change of this enb pin is (1/8)mhz. how do i use this external pin to my software....? p { margin-bottom: 0.21cm; } //this is the system.h contents with respect to the added enb input pin /* * pio_in_enb configuration * */ #define ALT_MODULE_CLASS_pio_in_enb altera_avalon_pio #define PIO_IN_ENB_BASE 0x10001560 #define PIO_IN_ENB_BIT_CLEARING_EDGE_REGISTER 0 #define PIO_IN_ENB_BIT_MODIFYING_OUTPUT_REGISTER 0 #define PIO_IN_ENB_CAPTURE 0 #define PIO_IN_ENB_DATA_WIDTH 1 #define PIO_IN_ENB_DO_TEST_BENCH_WIRING 0 #define PIO_IN_ENB_DRIVEN_SIM_VALUE 0x0 #define PIO_IN_ENB_EDGE_TYPE "NONE" #define PIO_IN_ENB_FREQ 82500000u #define PIO_IN_ENB_HAS_IN 1 #define PIO_IN_ENB_HAS_OUT 0 #define PIO_IN_ENB_HAS_TRI 0 #define PIO_IN_ENB_IRQ -1 #define PIO_IN_ENB_IRQ_INTERRUPT_CONTROLLER_ID -1 #define PIO_IN_ENB_IRQ_TYPE "NONE" #define PIO_IN_ENB_NAME "/dev/pio_in_enb" #define PIO_IN_ENB_RESET_VALUE 0x0 #define PIO_IN_ENB_SPAN 16 #define PIO_IN_ENB_TYPE "altera_avalon_pio" //this is my software routine which tried to read incoming enb pulse..... do { enb = IORD_ALTERA_AVALON_PIO_DATA(PIO_IN_ENB_BASE); //Check For Rx Interrupt if (enb) { //doing my job } printf(“\nenb = %d”,enb); } while (my condition)); kaushalLink Copied
What's driving the pin? Did you assign enb to any pins?
If the signal is coming from an external interface (eg a GPIO) you need to assign enb as an "input" and assign it to the corresponding pin in assignment editor.- Mark as New
Topic Options
