12453 Discussions
how to use external signal on nios2 in software
I have add a pin namely “enb” on nios processor as display in attached print-screen, every time this pin got high pulse. my IORD_..function read this pulse and start doing my further job.
i have seen through oscilloscope that enb pulse is keep coming but my software routine could not read this pin ...it always says “enb = 0”
Rate of change of this enb pin is (1/8)mhz.
how do i use this external pin to my software....?
p { margin-bottom: 0.21cm; }
//this is the system.h contents with respect to the added enb input pin
* pio_in_enb configuration
#define ALT_MODULE_CLASS_pio_in_enb altera_avalon_pio
#define PIO_IN_ENB_BASE 0x10001560
#define PIO_IN_ENB_BIT_CLEARING_EDGE_REGISTER 0
#define PIO_IN_ENB_BIT_MODIFYING_OUTPUT_REGISTER 0
#define PIO_IN_ENB_CAPTURE 0
#define PIO_IN_ENB_DATA_WIDTH 1
#define PIO_IN_ENB_DO_TEST_BENCH_WIRING 0
#define PIO_IN_ENB_DRIVEN_SIM_VALUE 0x0
#define PIO_IN_ENB_EDGE_TYPE "NONE"
#define PIO_IN_ENB_FREQ 82500000u
#define PIO_IN_ENB_HAS_IN 1
#define PIO_IN_ENB_HAS_OUT 0
#define PIO_IN_ENB_HAS_TRI 0
#define PIO_IN_ENB_IRQ -1
#define PIO_IN_ENB_IRQ_INTERRUPT_CONTROLLER_ID -1
#define PIO_IN_ENB_IRQ_TYPE "NONE"
#define PIO_IN_ENB_NAME "/dev/pio_in_enb"
#define PIO_IN_ENB_RESET_VALUE 0x0
#define PIO_IN_ENB_SPAN 16
#define PIO_IN_ENB_TYPE "altera_avalon_pio"
//this is my software routine which tried to read incoming enb pulse.....
do
enb = IORD_ALTERA_AVALON_PIO_DATA(PIO_IN_ENB_BASE); //Check For Rx Interrupt
if (enb
//doing my job
printf(“\nenb = %d”,enb);
} while (my condition));
kaushal
What's driving the pin? Did you assign enb to any pins?
If the signal is coming from an external interface (eg a GPIO) you need to assign enb as an "input" and assign it to the corresponding pin in assignment editor.
i am able to get signal on external pin...
Software routine make STRT signal high when i see this signal on SIGNAL TAB,sometime it show LOW..even though i haven't made it low...
plz see the attached printscreen
