Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
how to use hostfs in IDE
how to use the hostfs(file system) that altera provided .
i want to read data from file in my computer
when it evoke the alt_hostfs_open() function and execute where
(__asm__ volidata) ,it can not continue.
who can use it?
thanks
--- Quote Start ---
who can use it?
thanks
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15413)
--- quote end ---
--- Quote End ---
the hostfs is added as software component
mount:/mnt/host
but i can&#39;t open file when using fp=fopen(/mnt/host/test","r")
fp always returns 0
why?
Why don&#39;t you try the host filing system example, shipped with the 5.1 kit? It seem to work, just fine, here, and contains useful comments about how/why it works...
- slacker
thank you
i try
Hi
I record a tutorial on how to mount text file using NIOS II Processor and hostfs feature which enables us to mount files (such as text file) and perform read and write operation on that file
http://youtu.be/kbicxwtfbiy (http://youtu.be/kbicxwtfbiy)
