how to use the spi interface?
I have some problems about the writing of driver of spi interface?
I use the nios_apex_20k200 board ,because there are no example of the spi diver
so I can't make it ,I want to know how to write the driver of it .
I use it to drive a adc
thank you so much !!!
my email is wreadlee@hotmail.com
please give me the mail
I am developing spi C code for a 24 bit serial DAC.
I would like to see dedicated IP for serial DACs and ADCs. Using SPI looks doable but the 24 bit stuff is a challange. I had Max+II logic in schematic form but would like to see vhdl or verilog for standard parts.
I found these files useful ...
C:\altera\kits\nios2\components\altera_avalon_spi\HAL\src\altera_avalon_spi.c
C:\altera\kits\nios2\components\altera_avalon_spi\HAL\inc\altera_avalon_spi.h
C:\altera\kits\nios2\components\altera_avalon_spi\inc\altera_avalon_spi_regs.h
C:\altera\kits\nios2\components\altera_avalon_spi\sdk\spi_struct.h
Standard parts like?
If you're talking simple stuff like muxes, shift regs, etc.... then try the templates in quartus / maxplus (that's the recommended way to implement on Altera devices)
--- Quote Start ---
originally posted by eskotek@Aug 16 2004, 03:29 PM
i am developing spi c code for a 24 bit serial dac.
i would like to see dedicated ip for serial dacs and adcs. using spi looks doable but the 24 bit stuff is a challange. i had max+ii logic in schematic form but would like to see vhdl or verilog for standard parts.
i found these files useful ...
c:\altera\kits\nios2\components\altera_avalon_spi\hal\src\altera_avalon_spi.c
c:\altera\kits\nios2\components\altera_avalon_spi\hal\inc\altera_avalon_spi.h
c:\altera\kits\nios2\components\altera_avalon_spi\inc\altera_avalon_spi_regs.h
c:\altera\kits\nios2\components\altera_avalon_spi\sdk\spi_struct.h
--- Quote End ---
could you give the document of spi ?
what i use now is niosI ,so there are no copy of that ,thank you for giving me the doc!
