i2c ip core
RPALO3
IOWR_32DIRECT command is used in open core i2c (ie, oc_i2c_master) in nios. can we use the same code in i2c_master in nios.
can anyone help in this.
Ahmed_H_Intel1
can you please explain more. BTW there are some useful examples you can find here(https://fpgacloud.intel.com/devstore/?search=i2c), please give me more info to help you.
RPALO3
HI, Thank you so much. I will try according to the link you have sent. I will reply back to you.
Ahmed_H_Intel1
let me know if it works with you. :)
