12604 Discussions
implement interrupt by using custom component?
I want to implement interrupt by using custom component,fist I write a verilog HDL code;second ,i add it in Sopcbulider;at last,I write programme in IDE.
but i found that the interrupt can't happen.
whether you can give me some suggest or example code on iterrupt,Thank all
verilog HDL code(this is very small code )
module test(
clk,
reset,
write,
writedata,
irq
//inpnt signal
input clk;
input reset;
input write;
input [31:0]writedata;
//output signal
output irq;
//Parameter
parameter countval = 32'h0000_0010;
reg [31:0]count;
reg [31:0]ctl_reg;
wire irq_enable;
wire time_over;
assign irq = irq_enable && time_over;
always@(posedge clk or negedge reset)
begin
if(~reset)
count = 0;
else if(count >=countval)
count = 0;
else
count = count +1;
end
always @(posedge clk or negedge reset)
begin
if (~reset)
ctl_reg <= 0;
else if (write)
ctl_reg <= writedata;
end
assign irq_enable = ctl_reg;
assign time_over = (count >=countval);
endmodule
___________________________________________________________
NIOS IDE C code# include <stdio.h># include <io.h># include "system.h"# include "sys/alt_irq.h"
void test_interrupt(void* context, alt_u32 id)
IOWR(TEST_0_BASE,0,0x0); // CLEAR INTERRUPT
printf("Hello!\n");
IOWR(TEST_0_BASE,0,0x1);
int main()
int u;
printf("Hello from Nios II!\n");
u=alt_irq_register(TEST_0_IRQ,0,test_interrupt);
//alt_irq_enabled();
IOWR(TEST_0_BASE,0,0x1); // enable interrupt
printf("Nios II!=%d\n",u);
while(1);
return 0;
I found it never interrupt ; what wrong with my work? I need help
