Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
kbhit() for NIOS terminal
I need an implementation of kbhit() for the nios terminal in eclipse. I found the following example
# include <termios.h>
int kbhit(void)
struct termios term, oterm;
int fd = 0;
int c = 0;
tcgetattr(fd, &oterm);
memcpy(&term, &oterm, sizeof(term));
i tried but i got an error, so i insertet the function "tcgetattr" directly
# include <termios.h># include <sys/ioctl.h>
int
tcgetattr(int fd,struct termios *termios_p)
return ioctl(fd,TCGETS,termios_p);
-> Now i have the problem, that he can&#39;t find "TCGETS" !! it seems to be defined nowhere ?????
Did you solve this non-blocking getch() issue. I have searched and searched to no avail. My next thought would be to create a thread to do it...
Simon
fcntl() should be supported, non-blocking operations (including getch()) certainly are.
