Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
kernel build fails
I have uClinux1.3 on a Nios2 IDE 1.1 and Quartus 4.2, and I try to run a kernel compilation, I did not modify the kernel config.
I get an error :
Error: expected comma after "nobreak"[/cygdrive/c/altera/kits/nios2.1.1/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/entry.S] (line 43)
Is it due to a bug in the new distribution ?
cetic
Highlighted
Re: kernel build fails
Can you get me the version of your nios2-elf-gcc application?
nios2-elf-gcc --version
Highlighted
the version returned is :
nios2-elf-gcc (GCC) 3.4.1 (Altera Nios II 1.1 b137)
Nb : I fixed the problem by replacing "nobreak" by "nobreak,0", and the corresponding "break" by "break,0", it seems to be ok.....
cetic
Highlighted
I'm a little concerned because that error didn't come up at all during our testing... it's good to know though. Thank you cetic.
