12603 Discussions
lockup problems, altera nios2 web server demo
Hi Everybody -
We have been working on a project using nios2/lwip/ucosii.
Development is taking place on a cyclone eval board, and we
are now using the "release" version of the nios 2 development
system.
We wrote some a test code for use with the "out of the box" untouched
web server application. The code repeatedly hits the nios board with
http get requests.
We are seeing:
(1) there is an occasional pause which occurs when the test code
is trying to connect. This pause occurs typically once out of a series
of 20-200 accesses and lasts for about a second or two before
resuming. During the pauses, the system nios board continues to
respond properly to ping requests. It is suspected that there are some
old connections left laying around, and when a limit is reached, a delay
is caused until a connection frees up. This behaviour is a bit strange,
but not fatal.
(2) More troubling, after typically about 500-25000 accesses, the board
consistently locks up. At this point, the board seems totally dead, and
does not respond to pings.
Has anyone experienced anything similar?
The code to do the repeated http requests (a linux/unix application) is here:
http://phntm.com/nios/hammer.tgz (http://phntm.com/nios/hammer.tgz
The command used was:
hammer 172.25.1.81 80 index.html 1000000 10000
Hi Fred,
I did the web server demo on Nios II. Part of its design is, when over-burdened with connection requests (something that can easily happen running at a slow clock speed, with no d-cache, and no protocol stack optimizations as we have the HTTP server running on). It will handle a couple of simultaneous HTTP sessions (from people hitting it with web browses), but that is it.
Like a full-fledged HTTP server we designed it to ignore incoming connection requests that it cannot service, and only to heed those connections when the previous ones are complete. If you *really* hammer on it, its designed to reset any connections that get into a bad state and recover after 5 seconds. However, what you describe sounds like a more legitamate failure we haven't seen... just curious, did you submit your 'hammer' application to Altera's mysupport? If that was you, I wanted to let you know that I got notification from our support engineer on your case about this last night; I have your app. and will likely be taking a detailed look at the problem today.
- Trogdor (real name is Jesse)
Hi Trogdor -
The "hammer" app was indeed submitted to Altera's mysupport earlier by a co-worker.
Thanks for looking into this problem for us.
-Fred
