12409 Discussions
<Board Update Portal based on Nios II Processor with EPCQ> example....
In the Cyclone V E FPGA Development Kit, I would like to use the reference on the <Board Update Portal based on Nios II Processor with EPCQ>.
I wonder, can EPCQ memory be used differently from its original purpose?
For example, it can be used as a buffer for Ethernet communications, to store Ethernet IPs, to write or read other data, etc.
Looking at Qsys, it appears that the data output from the EPCQ controller is not set up
--- Quote Start ---
--- Quote End ---
If the FPGA configuration data does not fill up the entire EPCS/EPCQ device, any left-over space can be used for general-purpose data and system startup code.
--- Quote Start ---
--- Quote End ---
You can use "legacy EPCS/EPCQ Serial Flash Controller" IP Core or Alter ASMI parallel Ip.
Refer below links.Page 165 & 167:https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf
https://www.altera.com/en_us/pdfs/literature/ug/ug_altasmi_parallel.pdf
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-asmi2.pdf
For Remote configuration over Ethernet with Nios II refer https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an429.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
