I never met this before. succeed in uClinux2007,uClinux2009.But crashed in uClinux2010* .
root@spomu-desktop:/home/work/uClinux-dist201010# make vendor_hwselect SYSPTF="/home/work/niosII.ptf" make ARCH=nios2nommu -C vendors vendor_hwselect make[1]: Entering directory `/home/work/uClinux-dist201010/vendors' make -C /home/work/uClinux-dist201010/vendors/Altera/nios2nommu/. dir_v=/home/work/uClinux-dist201010/vendors/Altera/nios2nommu/. -f /home/work/uClinux-dist201010/vendors/vendors-common.mak vendor_hwselect make[2]: Entering directory `/home/work/uClinux-dist201010/vendors/Altera/nios2nommu' [ -d /home/work/uClinux-dist201010/romfs/$i ] || mkdir -p /home/work/uClinux-dist201010/romfs make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- CFLAGS_KERNEL="" AFLAGS_KERNEL="" -C /home/work/uClinux-dist201010/linux-2.6.x hwselect no emulation specific options. make[3]: Entering directory `/home/work/uClinux-dist201010/linux-2.6.x' RUNNING hwselect Can't locate PTF/SystemPTF.pm in @INC (@INC contains: /arch/nios2nommu/scripts /etc/perl /usr/local/lib/perl/5.10.0 /usr/local/share/perl/5.10.0 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl .) at /home/work/uClinux-dist201010/linux-2.6.x/arch/nios2nommu/scripts/hwselect.pl line 8. BEGIN failed--compilation aborted at /home/work/uClinux-dist201010/linux-2.6.x/arch/nios2nommu/scripts/hwselect.pl line 8. make[3]: *** [hwselect] error 2 make[3]:Leaving directory `/home/work/uClinux-dist201010/linux-2.6.x' make[2]: *** [vendor_hwselect] error 2 make[2]:Leaving directory `/home/work/uClinux-dist201010/vendors/Altera/nios2nommu' make[1]: *** [vendor_hwselect] error 2 make[1]:Leaving directory `/home/work/uClinux-dist201010/vendors' make: *** [vendor_hwselect] error 2 Why the same perl enviroment cause different results by changing uClinux version?I found that files in dir "arch" are all the same among kenerl linux2.6.x 2007,2009&2010 This block me for a long time , need help ~~~Link Copied
seems that you didn't choose the right branch for it. if you use the noMMU version the output ofgit branch
should be that test-nios2 is selected. so this must be selected in the 'uClinux-dist' as well as in the 'linux2.6' folder. I don't know if the noMMU also works with the "trunk"-branch from "nios2 linux distribution". Even if this is possible the command make vendor_hwselect
is not used in the "new" distribution. Urmel
