12455 Discussions
master_write_32 doesn't come out of master
I have instantiated a JTAG to MM Master block in my FPGA. I can attach to it from the system console and open it without problem.
However, when I try to do a simple write:
master_write_32 $path 0x0 0xdeadbeef
It doesn't come out of the master according to signaltap.
When I try to read it back:
master_read_32 $path 0x0 1
I get:
0x000000ef. - only the low-order byte
If I write multiple words, it still takes only that one byte and it doesn't send it out. I'm guessing that it's storing it internally.
I thought maybe I needed some kind of slave in there, so I instantiated a (redundant) Slave to Master Bridge with full address map enabled and still get the same problem.
Any ideas what could cause this?
Thanks in advance.
One issue was that I was using a master from the 5M chip rather than the Arria 10 on our board.
That's because my master wasn't showing up with get_service_paths when I used the gui, even if I gave it the proper -device switch.
Instead, what did work was using the command line:
quartus_sh -s
tcl> load_package systemconsole
tcl> initialize_systemconsole
tcl> get_service_paths master
[all masters are shown. My showed up as .../phy_0/master]
tcl> master_write ... - it worked
