max 10 neek udp client
aiedb
hii
i want to do a udp client  project
the max10_neek div board will be a udp_client that sends a message periodically to a pc (the pc will be a udp server ) , the pc  will receive the message and send a reply to the udp client (max10 neek)
is there any example design that's gets me started  ?
hareesh
i think bellow one is closest to your requirement. please try this
https://www.intel.com/content/www/us/en/design-example/714914/max-10-nios-ii-simple-socket-server-ethernet-example.html?
aiedb
hii thanks for your reply
i know this example and i activated it on my board
its close but not enough
i want to to send udp message from the max10 neek development board to the pc , for example
"hello server , i am the client"
and the pc will sent a reply to the  max10 neek development board
"hello client , i got you"
the max 10 board will receive this message back from the server and toggles a led or display a number on the 7 sig . it doesn't matter
this for indication that max10 board received a udp message  .
what i am looking to do is to build client-server relationship between the max10-neek and my pc using udp protocol
hareesh
Sorry, Right now we have that example design only.
i will request engineering team for this from my side, bit it takes some time.
aiedb
THANKS I WILL BE GLAD TO GET FURTHER UPDATE
hareesh
if you don't have any queries about this i will close this case. please conform it.
aiedb
hii thanks
you can close it
