12603 Discussions
mounting SD Card on uClinux
Hi everyone,
I'm trying to implement a fat file system on sd card
I followed the instructions for Altera SPI Core on this page
http://www.nioswiki.com/operatingsystems/uclinux/mmcsd
didn't work...
was I suppose to use SPI (3 wire) IP?
thanks,
Asaf
Yep.
Using the fast (nonSPI) SD-Card interface interface requires joining the SD-Card Organization and paying money for the license. So you need to stick with the slow SPI interface, unless you want to do so.
There are commercial SD-Card IP-Cores available that enable the use of this interface.
-Michael
thanks but I'm into the free stuff :)
maybe I configured somthing wrong in the IP...
--- Quote Start ---
Hi everyone,
didn't work...
--- Quote End ---
What claims does your kernel say?
Kazu
well, I'm still stuck
I thought I'd see something like this
--- Quote Start ---
Freeing unused kernel memory: 676k freed (0x1f6000 - 0x29e000)
mmc0: new SD card on SPI
mmcblk0: mmc0:0000 TWTTI 124672KiB
mmcblk0: p1 p2
--- Quote End ---
on boot, as ashown in nioswiki
so I thought of a few possible problems
1. pin assignments
2. IP core not configured as should
3. driver not loaded
now I'm down to either it's an IP problem or driver problem
so just to make sure again
it is Altera's SPI (3 wire interface) IP, right? not someone else's similar IP?
and if so could someone show me the right configuration?
Thanks again,
Asaf
I just recently went through getting the SD card working on my DE2-70 board and was able to finally mount my 4 GB SD card with a standard vfat file system. Here's what I did, let us know if this helps you get yours working...
1) I started my project by using the DE2_70_NET project found on Terasic's DE2-70 CD freely available on their site. I'd start with that if you happen to be using that board. In any case, it might be a good reference.
I had to remove the GPIO pins they used for SD card access as it's not compatible with the uClinux MMC/SD/SDIO over SPI driver. Then I added a new component "SPI (3 wire serial)" to my SOPC builder design called mmc_spi (I think the name matters as uClinux drivers look for it) at base address 0x09606000 (address probably doesn't matter as long as there's no conflict).
2) I had to change the assignment of pins in the top level design (DE2_70_NET.v), removing references to SD_* components which no longer exist, and adding the following lines starting at 549 (seemed like a good place)...
Line 549: // the_mmc_spi (SD Card Slot)
Line 550: .SCLK_from_the_mmc_spi(oSD_CLK),
Line 551: .MOSI_from_the_mmc_spi(SD_CMD),
Line 552: .MISO_to_the_mmc_spi(SD_DAT),
Line 553: .SS_n_from_the_mmc_spi(SD_DAT3),
Then I compiled the design.
3) Changes to the Kernel config: (Anything not explicitly shown as added was kept as is, if it was added by default I left it alone and didn't remove it) -- forgive underscores here, I can't get this forum to properly indent with whitespace
--> Device Drivers
___ * --> SPI Support
_________* Altera SPI Controller
--> Device Drivers
____* --> mmc/SD/SDIO Support
_________* mmc/SD/SDIO over SPI
--> File Systems
___--> Native Language Support
_______* Codepage 437 (US, Canada)
_______* NLS ISO 8859-1 (Latin 1...
4) Recompiled the kernel.
5) Booted the design.
If things went well, you should see something like this as your kernel boots (without a card installed)...
mmc_spi spi2.0: ASSUMING SPI bus stays unshared!
mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power
mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff
<No further mmc_sip messages at bootup>
With my 4 GB SD card inserted it'll look like this...
<A few other lines of booting messages>
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SDHC card on SPI
mmcblk0: mmc0:0000 SD04G 3.69 GiB
mmcblk0:Command: mount -t proc proc /proc -o noexec,nosuid,nodev
p1
Then at the command prompt provided mount is in your kernel's app config somewhere (I think it is by default?) just type the following...
/> mount -t vfat /dev/mmcblk0p1 /mnt
/> ls -l /mnt
drwxrwxrwx 3 root root 4096 Oct 17 2009 FPGADev
drwxrwxrwx 2 root root 4096 Nov 29 16:04 NewFolder
-rwxr-xr-x 1 root root 20 Nov 2 2009 newerfile.txt
Hopefully that'll show you what's on your SD card!
I hope this helps you out. Good Luck!
--- Quote Start ---
1. pin assignments
--- Quote End ---
The kernel messages
mmc0: new SD card on SPI mmcblk0: mmc0:0000 TWTTI 124672KiB mmcblk0: p1 p2 show that your SD card has 124672Kbyte volume and 2 partitions. If it is right, please consider well why your kernel knows such thing. Without several communications between your kernel and SD, it can't display those information.
And did you execute the 'mount' command? For example, please type
root> mount -t vfat /dev/mmcblk0p1 /mnt to mount your SD's partition 1 for /mnt. (Opps, before to do this, please check the major number of /dev/mmcblk0p1 with 'ls /dev/mmcblk0p1 -l'. The number must be 179.:D)
...And, what is the claim?
Kazu
hi eltoddo,
thanks for the help but
1. my design is written in vhdl so, not *_top.v
2. I did the rest of the steps but with or without the sd card I get no mmc_spi message at boot
any idea why?
btw, I'm using Terasic's DE0 dev board if it helps...
ok, here's an update
it appears that there's a BIG difference between
[*] and <M> (my bad;) )
so the good news are that it worked only when I selected my options as
the bad new are... well... when I use
mount -t vfat /dev/mmcblk0 /mnt
I get Invalid argument error
any ideas?
ok, now it's officialy closed!
I just needed to format my sd card using mkfs.vfat command
or through windows :S
anyway, thanks for all your help and support! :D
I have the same problem&#65292;don't know how to handle it.
just display the message above ,no other messages,who can give me helps?
... This output seems OK. What is the problem ?
-Michael
but when I try to moun it
mount: mounting /dev/mmcblk0p1 on /mnt failed: No such device or address
I have insert 4GB SDcard&#65292;but cannot found the message above and cannot mount it.
p1
(using the drivers as modules), to allow for Linux and Windows formatted cards, which uses different partition tables)I do this:
modprobe mmc_block
modprobe mmc_spi# sd card formatted by Windows (no parition table)
mount -t vfat /dev/mmcblk0 /mnt/sdcard# sd card formatted by Linux (first parition)
mount -t vfat /dev/mmcblk0p1 /mnt/sdcard
I want know why after I use nios2-terminal command, I cann't see the display messages above,is the hardware problem or pin assign problem?
"mmc0: host does not support reading read-only switch. assuming write-enable.
DO you means that I should download the zImage and mmc_block.o and mmc_spi.o at first ?and modprobe mmc_block and mmc_spi ?
I make zImage with mmc_block.o and mmc_spi.o.
"nios2-linux/uClinux-dist/linux-2.6.x/drivers/mmc/host/mmc_spi.o"
"nios2-linux/uClinux-dist/linux-2.6.x/drivers/mmc/card/mmc_block.o"
Sorry. Most of your messagge does not make sense to me. Please rephrase.
I suppose the "Read only switch" is not supported by the hardware.
-Michael
again:
At first, after command nios2-download and nios2-terminal,just display "
" no other message as
follow your suggestion ,I have donwnload zImage , mmc_block.o and mmc_spi.o,and modporbe it ,but display errors like
:modprobe : chdir <2.6.30>no such file or directory.
I see this:
Command: mkdir /mnt/sdcard
Command: /etc/mount_sdcard
Shell invoked to run file: /etc/mount_sdcard
Command: modprobe mmc_block
Command: modprobe mmc_spi
Command: mount -t vfat /dev/mmcblk0 /mnt/sdcard
mmcblk0: mmc0:0000 121 MiB
mmcblk0:
Command: mount -t vfat /dev/mmcblk0p1 /mnt/sdcard
mount: mounting /dev/mmcblk0p1 on /mnt/sdcard failed: No such device or address
Execution Finished, Exiting
Thus mmcblk0 is mounted, while mounting /dev/mmcblk0p1 fails, as this is a Windows-formatted SD-Card without a partition table.
-Michael
why I cannt see the message at the process of uclinux startup?
like
mmcblk0:
and when I typed "mount -t vfat /dev/mmcblk0 /mnt/sdcard "
also display "No such device or address
we know than :(
-Michael
