mouting SD card on uClinux
I read the post about MMC/SD on altera wiki and followed this instruction but get this error
I used hardware of DE2_NIOS_HOST_MOUSE_VGA (DE2_Systemv1.6 CD), removed the components of SD (SD_DAT, SD_CLK,SD_CMD) in SOPC builder, then i deleted these lines:
// All inout port turn to tri-state
assign SD_DAT = 1'bz;
// Set SD Card to SD Mode
//assign SD_DAT3 = 1'b1;
.out_port_from_the_SD_CLK(SD_CLK),
.bidir_port_to_and_from_the_SD_CMD(SD_CMD),
.bidir_port_to_and_from_the_SD_DAT(SD_DAT),
*insert 4 lines code from wiki
.MISO_to_the_mmc_spi (SD_DAT),
.MOSI_from_the_mmc_spi (SD_CMD),
.SCLK_from_the_mmc_spi (SD_CLK),
.SS_n_from_the_mmc_spi (SD_DAT3),
then generate and compile this projects
after i used file system_0.ptf to make kernel and set config
Device Drivers -->
[*] SPI support --->
[*] Altera SPI Controller
[*] MMC/SD card support --->
[*] MMC block device driver
[*] Use bounce buffer for simple hosts
[ ] SDIO UART/GPS class support
[ ] MMC host test driver
*** MMC/SD Host Controller Drivers ***
[*] MMC/SD over SPI
but when i boot with the SD card 1GB FAT, i see the messages
mmc_spi spi2.0: ASSUMING SPI bus stays unshared!
mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power
mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Freeing unused kernel memory: 676k freed (0x1f6000 - 0x29e000)
but i can't see messages deteced MMC/SD or other messages
mmc0: new SD card on SPI
mmcblk0: mmc0:0000 TWTTI 124672KiB
plese help me
Please help me, i searched these post about this problem on forum but no resulst
