12500 Discussions
multicycle custom instruction not working
Hi All,
I am trying a 3 cycle (fixed) multi cycle instruction module with nios2.
below s my interface.
port (
clk : in std_logic := '0';
reset : in std_logic := '0';
clk_en : in std_logic := '0';
start : in std_logic := '0';
dataa : in std_logic_vector(31 downto 0) := (others => '0');
datab : in std_logic_vector(31 downto 0) := (others => '0');
result : out std_logic_vector(31 downto 0)
here 'start' signal is never becoming '1' during my custom call. Also my module s getting only single cycle.
if clk_en = '1' then
if start ='1' then
count <= 10;
reg_out <= "0000010101001111";
elsif count = 1 then
reg_out <= "1100110101001111";
count <= 0;
else
reg_out <= reg_out;
count <= count+1;
end if;
here my reg_out always coming 0
count is also coming 0 always.
(NOTE: from software side the instruction is going correctly as per (ug_nios2_custom_instruction.pdf) -- ie opcode is 0x32 N value s all 0s,
a,b,c reg values are set proeprly.
Also in sopc builder the added custom instruction is shwing its a 3 cycle fixed multicycle instruction.)
Please help.
Also i cud make combinatorial module work proeprly.
Please help soon.
Preethi
I'm no vhdl expert! but aren't you missing a test for the edge of 'clk' ?
I have the same problem. Same logic works when i implemented it as combinational, but since it has limitations i have to use multicycle custom instructions, however I couldn't get the correct result after running the project. In the Quartus ii timing simulation it shows the correct result after 4 cycles.
Thanks in advance for any support that you could provide.
Custom instruction Variable Cycles have 2 port: start; done. you don't have "done"
