Hello guys......
i using snmp in uClinux .....it works with the default mibs but i need to do my own mib file ....... anybody knows how can i do that???............ one exemple how can i monitore a peripherial..... thanks Franz WagnerLink Copied
where the uclinux jedis for help me !!!!!
I understand that the MIB file is part of the snmp standard and not spcific for NIOS or uClinux. So you should find in the internet what needs to be written there.
-Michael- Mark as New
ok.....
i post the result when i did work....... Franz Wagner- Mark as New
hi all!!!!
i did a simple mib that read a one memory address......and i have success creating a skeleton of mib ( .c and .h) i run ./configure --with-mib-modules=mymod and it add mymod ok but when i did make in kernel i had many errors with doesnt appears when i make in my system pc........the problem is in cross compile......:( someone, sometime , already implement a own mib????? can someone help me did that ??????? thanks Franz Wagner- Mark as New
nz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c ../../../net-snmp-5.2.1/agent/mibgroup/snmpv3/usmUser.c -o snmpv3/usmUser.o
In file included from ../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:22:
/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/net-snmp-5.2.1/include/ucd-snmp/ucd-snmp-includes.h:7:2:# error "Please update your headers or configure using --enable-ucd-snmp-compatibility"
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:23:139: /home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/net-snmp-5.2.1/include/ucd-snmp/agent/ucd-snmp-agent-includes.h: No such file or directory
In file included from ../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:29:
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.h:19: error: syntax error before "var_ladProject"
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:59: error: extra brace group at end of initializer
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:59: error: (near initialization for `ladProject_variables')
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:60: error: `
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:298: error: 'write_ladAlarmLatching' redeclared as different kind of symbol
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.h:24: error: previous declaration of 'write_ladAlarmLatching' was here
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `write_ladAlarmLatching':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:303: error: `action' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:304: error: `RESERVE1' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:305: error: `var_val_type' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:306: error: `stderr' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:307: error: `SNMP_ERR_WRONGTYPE' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:309: error: `var_val_len' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:311: error: `SNMP_ERR_WRONGLENGTH' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:316: error: `RESERVE2' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:318: error: `var_val' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:324: error: `FREE' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:329: error: `ACTION' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:336: error: `UNDO' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:341: error: `COMMIT' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:346: error: `SNMP_ERR_NOERROR' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: At top level:
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:354: error: syntax error before "u_char"
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:360: error: 'write_ladAlarmState' redeclared as different kind of symbol
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.h:25: error: previous declaration of 'write_ladAlarmState' was here
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `write_ladAlarmState':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:365: error: `action' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:391: error: `ACTION' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:398: error: `UNDO' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:403: error: `COMMIT' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:408: error: `SNMP_ERR_NOERROR' undeclared (first use in this function)
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `var_ladProject':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:113: error: storage size of `string' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:115: error: storage size of `c64' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c: In function `var_ladAlarmTable':
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:166: error: storage size of `string' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:168: error: storage size of `c64' isn't known
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:57: warning: array 'ladProject_variables' assumed to have one element
../../../net-snmp-5.2.1/agent/mibgroup/ladProject.c:57: error: storage size of `ladProject_variables' isn't known
nios2-linux-uclibc-gcc -O2 -g -fno-builtin -I../../include -I../../../net-snmp-5.2.1/include -I. -I../../agent -I../../../net-snmp-5.2.1/agent -I../../agent/mibgroup -I../../../net-snmp-5.2.1/agent/mibgroup -I../../snmplib -I../../../net-snmp-5.2.1/snmplib -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c ../../../net-snmp-5.2.1/agent/mibgroup/snmpv3/snmpMPDStats.c -o snmpv3/snmpMPDStats.o
echo timestamp > snmpv3/usmStats.lo
/bin/sh ../../libtool --mode=compile nios2-linux-uclibc-gcc -O2 -g -fno-builtin -I../../include -I../../../net-snmp-5.2.1/include -I. -I../../agent -I../../../net-snmp-5.2.1/agent -I../../agent/mibgroup -I../../../net-snmp-5.2.1/agent/mibgroup -I../../snmplib -I../../../net-snmp-5.2.1/snmplib -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c -o util_funcs.lo ../../../net-snmp-5.2.1/agent/mibgroup/util_funcs.c
make: ** Erro 1
make: ** Esperando que outros processos terminem.
echo timestamp > snmpv3/snmpMPDStats.lo
echo timestamp > snmpv3/usmUser.lo
nios2-linux-uclibc-gcc -O2 -g -fno-builtin -I../../include -I../../../net-snmp-5.2.1/include -I. -I../../agent -I../../../net-snmp-5.2.1/agent -I../../agent/mibgroup -I../../../net-snmp-5.2.1/agent/mibgroup -I../../snmplib -I../../../net-snmp-5.2.1/snmplib -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/franz/altera/linux/nios2-linux/uClinux-dist -I/home/franz/altera/linux/nios2-linux/uClinux-dist/linux-2.6.x/include -I/home/franz/altera/linux/nios2-linux/uClinux-dist/staging/usr/include -D__adjtimex=adjtimex -O2 -g -fno-builtin -Dlinux -c ../../../net-snmp-5.2.1/agent/mibgroup/util_funcs.c -o util_funcs.o
echo timestamp > util_funcs.lo
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/build/agent/mibgroup'
make: ** Erro 1
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/build/agent'
make: ** Erro 1
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp/build'
make: ** Erro 2
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user/net-snmp'
make: ** Erro 2
make: Saindo do diretório `/home/franz/altera/linux/nios2-linux/uClinux-dist/user'
make: ** Erro 2
make: ** Erro 1
franz@franz-desktop:~/altera/linux/nios2-linux/uClinux-dist$
here an error what i did ........ i already add --enable-ucd-snmp-compatibility but doent work i guess..............
Hi guys !!!!!!!!
i have success compiling my own mib !!!!!! :) the problem was a simple header error............. now its workingfranz@franz-desktop:~$ snmpwalk -c public 192.168.100.137 enterprises
enterprises.23528.1.1.1.1.1.0 = Hex: 00 00 00 00
enterprises.23528.1.1.1.1.2.0 = 0
enterprises.23528.1.1.1.2.1.1.2.1 = Hex: 00 00 00 00
enterprises.23528.1.1.1.2.1.1.2.2 = Hex: 00 00 00 00
enterprises.23528.1.1.1.2.1.1.2.3 = Hex: 00 00 00 00
enterprises.23528.1.1.1.2.1.1.2.4 = Hex: 00 00 00 00
enterprises.23528.1.1.1.2.1.1.3.1 = 192
enterprises.23528.1.1.1.2.1.1.3.2 = 192
enterprises.23528.1.1.1.2.1.1.3.3 = 192
enterprises.23528.1.1.1.2.1.1.3.4 = 192
enterprises.23528.1.1.1.2.1.1.4.1 = 0
enterprises.23528.1.1.1.2.1.1.4.2 = 0
enterprises.23528.1.1.1.2.1.1.4.3 = 0
enterprises.23528.1.1.1.2.1.1.4.4 = 0
enterprises.23528.1.1.1.2.1.1.5.1 = 0
enterprises.23528.1.1.1.2.1.1.5.2 = 0
enterprises.23528.1.1.1.2.1.1.5.3 = 0
enterprises.23528.1.1.1.2.1.1.5.4 = 0
enterprises.23528.1.1.1.2.1.1.6.1 = Counter32: 0
enterprises.23528.1.1.1.2.1.1.6.2 = Counter32: 0
enterprises.23528.1.1.1.2.1.1.6.3 = Counter32: 0
enterprises.23528.1.1.1.2.1.1.6.4 = Counter32: 0
Great job. I'm interested to make snmp work on my uClinux too. How do you manage to make it work? Do you do the following ?- You select snmpd
- You select also net-snmp with "additional mibs options"
- You put your modules in the additional mibs
- Then when compiled you run snmpd on your target (snmpd -c <IPAddr of the target> -c public)
hi zben
follow me!!! at menuconfig select custumize Applications..... select net-snmp , build mini agent, build static, install mibs. make in your uclinux terminal do mkdir /etc/snmp in this directory you do a snmpd.conf and put rwcommunity public save at your desktop snmpwalk -c public 192.168.100.137 -> put your uclinux ip ........... if you want to do your own mib need other steps........ try it and report........ good luck Franz Wagner- Mark as New
Wow great !!
My error was to select in menuconfig the "package" snmpd that provide also a snmpd application that override the snmpd provided by net-snmp. So it works great (V1, V2c and V3). Thank you very much, maybe I will come back with issue with custom MIBs Best regards- Mark as New
:cool:
good job- Mark as New
Hi
i'm interested in compiling my own MIB in uclinux.. my snmp works fine but im not able to add my own MIB .. i followed the net-snmp tutorial but no avail ... regards Khushboo- Mark as New
hello Mr khushboo_q,
I'm sorry for the delay in reply........ to do you ow mib first you need to write your FILE-MIB.txt this file is used to generate a c skeleton... and look like this
LINEAR-MIB DEFINITIONS ::= BEGIN
IMPORTS
NOTIFICATION-TYPE,
MODULE-IDENTITY,
enterprises,
OBJECT-TYPE,
Counter32,
Integer32,
Gauge32
FROM SNMPv2-SMI
DisplayString,
TruthValue
FROM SNMPv2-TC
tsoipProject MODULE-IDENTITY
LAST-UPDATED "201105130000Z"
ORGANIZATION "LINEAR Equipamentos Eletronicos S/A."
CONTACT-INFO
"Contact: Franz Wagner
Postal: LINEAR Equipamentos Eletronicos S/A,
Praca Linear sn,
Santa Rita do Sapucai, MG,
Brasil,
Web: www.linear-tv.com
Email: fwagner@linear.com.br"
DESCRIPTION
"Rev. 1.33"
::= { linear 8 }
linear OBJECT IDENTIFIER ::= { enterprises 25026 }
-- top level MIB headings of the LAD MIB
tsoipTraps OBJECT IDENTIFIER ::= { tsoipProject 0 }
tsoipSystem OBJECT IDENTIFIER ::= { tsoipProject 1 }
tsoipTrapInfo OBJECT IDENTIFIER ::= { tsoipProject 2 }
-- LAD System Information
tsoipTables OBJECT IDENTIFIER ::= { tsoipSystem 1 }
-- TX Table
txTable OBJECT-TYPE
SYNTAX SEQUENCE OF LinearTxEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
"Tabelas com informacoes de Transmissao e Recepcao."
::= { tsoipTables 1 }
linearTxEntry OBJECT-TYPE
SYNTAX LinearTxEntry
STATUS current
DESCRIPTION
"Tabela de Transmissao."
INDEX { linearTxId }
::= { txTable 1 }
LinearTxEntry ::=
SEQUENCE {
linearTxId Integer32,
linearTxIp1 Integer32,
linearTxIp2 Integer32,
linearTxIp3 Integer32,
linearTxIp4 Integer32,
linearTxPort Integer32,
linearTxencap DisplayString,
linearTxpacket Integer32,
linearTxFec DisplayString,
linearTxFecV DisplayString,
linearTxEthBps Integer32
linearTxId OBJECT-TYPE
SYNTAX Integer32 (1..10)
STATUS current
DESCRIPTION
"Index da Tabela."
::= { linearTxEntry 1 }
linearTxIp1 OBJECT-TYPE
SYNTAX Integer32 (1..255)
MAX-ACCESS read-write
STATUS current
DESCRIPTION
"1 octeto do IP de Destino"
::= { linearTxEntry 2 }
linearTxIp2 OBJECT-TYPE
STATUS current
DESCRIPTION
"2 octeto do IP de Destino."
::= { linearTxEntry 3 }
linearTxIp3 OBJECT-TYPE
STATUS current
DESCRIPTION
"3 octeto do IP de Destino"
::= { linearTxEntry 4 }
linearTxIp4 OBJECT-TYPE
STATUS current
DESCRIPTION
"4 octeto do IP de Destino"
::= { linearTxEntry 5 }
linearTxPort OBJECT-TYPE
SYNTAX Integer32 (1..65525)
STATUS current
DESCRIPTION
"Porta de Destino"
::= { linearTxEntry 6 }
linearTxencap OBJECT-TYPE
SYNTAX DisplayString
STATUS current
DESCRIPTION
"Encapsulamento RTP ou UDP"
::= { linearTxEntry 7 }
linearTxpacket OBJECT-TYPE
SYNTAX Integer32 (1..7)
STATUS current
DESCRIPTION
"N de pacotes ts em cada pacote IP"
::= { linearTxEntry 8 }
linearTxFec OBJECT-TYPE
STATUS current
DESCRIPTION
"FEC habilitado ou desabilitado"
::= { linearTxEntry 9 }
linearTxFecV OBJECT-TYPE
STATUS current
DESCRIPTION
"Valor do Fec"
::= { linearTxEntry 10 }
linearTxEthBps OBJECT-TYPE
SYNTAX Integer32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"Taxa de transmissao na saida ETH"
::= { linearTxEntry 11 }
-- LAD traps
tsoipRefreshAlarm NOTIFICATION-TYPE
OBJECTS {refreshTrap}
STATUS current
DESCRIPTION
" Trap issued when an alarm is triggered. "
::= { tsoipTraps 1 }
-- LAD Trap Info: varbinds sent with traps
refreshTrap OBJECT-TYPE
SYNTAX Integer32
MAX-ACCESS accessible-for-notify
STATUS current
DESCRIPTION
"This is the Id (row number in the ladAlarmTable) of the
zone generating the alarm."
::= { tsoipTrapInfo 1 }
END
now you need a linux machine to walk away...... install net-snmp .... and put your mib at mibs directory /opt/net-snmp/mibs and run mib2c $mib2c LINEAR-MIB.txt:linearProject this generate two files : linearProject.h and linearProject.c ...... you need modify the .c file to do what you need....... and put this file at nios2-linux/uClinux-dist/user/net-snmp/net-snmp-5.2.1/agent/mibgroup add your mib at menuconfig and voila..... good luck Franz Wagner
Hi all,
I have a system with a nios2 and a network interface (Altera Triple speed Ethernet MAC). I use 2.6.30 kernel on my board and net-snmp 5.2.1. I can see my network interfaces using ifconfig : --- Quote Start --- /# ifconfig eth0 Link encap:Ethernet HWaddr 00:15:12:00:15:88 inet addr:192.168.0.110 Bcast:192.168.0.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1400 errors:0 dropped:681 overruns:0 frame:0 TX packets:400 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:205531 (200.7 KiB) TX bytes:33239 (32.4 KiB) Base address:0x400 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) --- Quote End --- So the systems know interface statistics. But I wonder why net-snmp is not able to handle these statistics automatically. I have the following : --- Quote Start --- /# snmpwalk -v 1 -c public 192.168.0.110 1 iso.3.6.1.2.1.1.1.0 = STRING: "XXX" iso.3.6.1.2.1.1.2.0 = OID: ccitt.1 iso.3.6.1.2.1.1.3.0 = Timeticks: (115) 0:00:01.15 iso.3.6.1.2.1.1.4.0 = STRING: "System Contact (configurable)" iso.3.6.1.2.1.1.5.0 = STRING: "System Name (configurable)" iso.3.6.1.2.1.1.6.0 = STRING: "System Location (configurable)" iso.3.6.1.2.1.1.7.0 = INTEGER: 2 iso.3.6.1.2.1.1.8.0 = Timeticks: (7) 0:00:00.07 iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.1 iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.16.2.2.1 iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.10.3.1.1 iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.11.3.1.1 iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.6.3.15.2.1.1 iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB module for SNMPv2 entities" iso.3.6.1.2.1.1.9.1.3.2 = STRING: "View-based Access Control Model for SNMP." iso.3.6.1.2.1.1.9.1.3.3 = STRING: "The SNMP Management Architecture MIB." iso.3.6.1.2.1.1.9.1.3.4 = STRING: "The MIB for Message Processing and Dispatching." iso.3.6.1.2.1.1.9.1.3.5 = STRING: "The management information definitions for the SNMP User-based Security Model." iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (5) 0:00:00.05 iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (6) 0:00:00.06 iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (6) 0:00:00.06 iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (6) 0:00:00.06 iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (7) 0:00:00.07 iso.3.6.1.2.1.11.1.0 = Counter32: 24 iso.3.6.1.2.1.11.2.0 = Counter32: 25 iso.3.6.1.2.1.11.3.0 = Counter32: 0 iso.3.6.1.2.1.11.4.0 = Counter32: 0 iso.3.6.1.2.1.11.5.0 = Counter32: 0 iso.3.6.1.2.1.11.6.0 = Counter32: 0 iso.3.6.1.2.1.11.8.0 = Counter32: 0 iso.3.6.1.2.1.11.9.0 = Counter32: 0 iso.3.6.1.2.1.11.10.0 = Counter32: 0 iso.3.6.1.2.1.11.11.0 = Counter32: 0 iso.3.6.1.2.1.11.12.0 = Counter32: 0 iso.3.6.1.2.1.11.13.0 = Counter32: 34 iso.3.6.1.2.1.11.14.0 = Counter32: 0 iso.3.6.1.2.1.11.15.0 = Counter32: 0 iso.3.6.1.2.1.11.16.0 = Counter32: 38 iso.3.6.1.2.1.11.17.0 = Counter32: 0 iso.3.6.1.2.1.11.18.0 = Counter32: 0 iso.3.6.1.2.1.11.19.0 = Counter32: 0 iso.3.6.1.2.1.11.20.0 = Counter32: 0 iso.3.6.1.2.1.11.21.0 = Counter32: 0 iso.3.6.1.2.1.11.22.0 = Counter32: 0 iso.3.6.1.2.1.11.24.0 = Counter32: 0 iso.3.6.1.2.1.11.25.0 = Counter32: 0 iso.3.6.1.2.1.11.26.0 = Counter32: 0 iso.3.6.1.2.1.11.27.0 = Counter32: 0 iso.3.6.1.2.1.11.28.0 = Counter32: 48 iso.3.6.1.2.1.11.29.0 = Counter32: 1 iso.3.6.1.2.1.11.30.0 = INTEGER: 2 iso.3.6.1.2.1.11.31.0 = Counter32: 0 iso.3.6.1.2.1.11.32.0 = Counter32: 0 iso.3.6.1.4.1.8072.2.1.1.0 = INTEGER: 43 iso.3.6.1.6.3.10.2.1.1.0 = Hex-STRING: 80 00 1F 88 80 28 B8 EF 53 96 13 43 38 iso.3.6.1.6.3.10.2.1.2.0 = INTEGER: 6 iso.3.6.1.6.3.10.2.1.3.0 = INTEGER: 1 iso.3.6.1.6.3.10.2.1.4.0 = INTEGER: 1500 iso.3.6.1.6.3.11.2.1.1.0 = Counter32: 0 iso.3.6.1.6.3.11.2.1.2.0 = Counter32: 0 iso.3.6.1.6.3.11.2.1.3.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.1.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.2.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.3.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.4.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.5.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.6.0 = Counter32: 0 iso.3.6.1.6.3.15.1.2.1.0 = INTEGER: 0 iso.3.6.1.6.3.16.1.1.1.1.0 = "" [...] --- Quote End --- So it is ok for the system mibs and some other infos, but nothing about my network interface (eth0)... My (simple) config : --- Quote Start --- rwcommunity private rocommunity public sysServices 2 sysDescr XXX interface eth0 6 100000000 --- Quote End --- As you can see I tried to add "interface eth0 6 100000000" to my conf file but it is not recognized by this version of net-snmp I can't figure out if net-snmp is able to "automatically" retrieve network interface, or if my issue is related to the nios2 linux environment I use. I googled a lot for nothing. Do I need to add a MIB in menuconfig (I tried mibII/ifTable mibII/interface mibII Rmon if-mib...) ? Do you have any idea ? Thanks- Mark as New
I think that I need succeed to add modules in menuconfig : mibII/ifTable mibII/interface mibII Rmon if-mib
But there is compilation errors, and if I let only mibII/interface snmpd hangs the system ...- Mark as New
Hello mr zben
try add your mib at computar that you do snmpwalk (i dont remenber what directory but look like Mibs) and add that mib at /user/net-snmp/.../mibs good luck Franz Wagner- Subscribe to RSS Feed
