12600 Discussions
networking without OS Support
Hello ,
I am trying to run networking application without Uc/OS-II Support, (not using standard UDP_Offload or Super_Loop)
for this i have choose the simple socket server server (RGMII) example and strip out OS feature one by one,
at the end it gives some error regarding
1. FindLastFlashSector
2. generate_and_store_mac_address
3. get_board_mac_addr
etc.
though i have add the network_utilities.c and network_utilities.h but still i am facing the problem
(see the attached printscreen of error)
i am using Altera Cyclone-II Development Board "Embedded Development board"
i have attached the c files
1.network_utilities.c
2.network_utilities.h
3.simple_socket_server.c
4.tse_my_system
kaushal
Those errors are due to a typo in simple_socket_server.c
You included
# include "network_utilities.c
instead of
# include "network_utilities.h"
Not done this myself, though might get there in the next few months. But I note that it says "multiple definitions" rather than not defined. If you look at your error list, it shows that you have one definition on line 23 and it is redefined on line 300 (or similar - can't see your attachment at the moment!). Have you got two copies of the code here?
Simon
--- Quote Start ---
You included# include "network_utilities.c
instead of# include "network_utilities.h
--- Quote End ---
Hello Thanking you
by adding network_utilities.h the error has gone
once again thanking you.
kaushal
where do i put alt_iniche_init() and netmain() function so that my network hardware initialize , till now i have put these two function in network_utilitiese.c and simple_socket_server.c but it haven't yet initilize and during run time (when i do run as a nios hardware) it says
panic: unlock NET
dtrap -need breakpoint (please see attached print screen)
regards
kaushal
if i add these two function in simple_socket_server.c
it generate bind error (please see attached print screen)
I've not told you in the previous post, but I was concerned you would be able to run an interniche application with neither OS nor superloop mode.
The alt_iniche_init and netmain functions are supposed to create specific tasks with OS. If you call them in a non-OS environment they probably generate some sort of exception or they are possibly blocking, thus preventing your application from working.
hello Cris,
me too think like this but , adding little delay after hardware initilize function alt_iniche_init() and netmain() ...it seems that it take MAC address and other things...but it stuck at Auto Negotiation pass etc(please see the print screen )
kaushal
TK_SLEEP is a OS specific function (or maybe a macro): it is supposed to release the control to other tasks, but you don't have any, so you can't use it.
I've seen non-OS implementations of sleep functions but they are blocking and they are only meant to add the time delay.
so is there any other way to go forward ...i mean what make hardware initialize up to "Auto Negotiation pass" not beyond that.
it seems that it going to work...if it go up to auto negotiation.
kaushal
Up to MAC and PHY initialization, OS is not involved, since those are execute-once functions.
You need OS features, superloop or any other interrupt scheduled process after inizialization when you really start sending and transmitting packets, especially if you need to manage a complex trasport protocol like tcp.
--- Quote Start ---
--- Quote End ---
I am working on UDP only for image data transmission.
earlier i am using uC/OS-II along with NicheStack having 64k data cache and 64 k Instruction chache, each time server (image source)sends high speed data my nios-ii based Client says "No free buffer for Rx" even though i have increase TSE_MAC FIFO rx buffer to its maximum limit.
so i plan to remove OS as it may taking lot's of space. and do the same exercise again
I don't think you'll save a lot of time by removing the OS. If you need UDP performance, you need some hardware acceleration instead. This is what FPGAs are for after all.
Dear Daixiwen,
Thanking you for your suggestion, in that case could you suggest me how to acquire this high speed UDP data.
regards
kaushal
The only example I know about is the udp offload (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example) example, but it will need some adaptations to the newest versions of Quartus I think.
--- Quote Start ---
--- Quote End ---
Hello Daixiwen,
I am using Quartus 11.0 SP1 and having Altera Embedded System Development Kit, Cyclone III Edition.
i have download the reference design from
http://www.alterawiki.co/wiki/nios_ii_udp_offload_example#3c120_port_2 (http://www.altera.com/products/devkits/altera/kit-emb-dev-cyc3.html)
so should i need to install Quartus 9.0S P2 as this design is based on Quartus 9.0 or it can be converted to Quatus 11.0 too.
kaushal
Hello There,
Compiling UDP affload design on quartus 9.0 SP2 generate en error:
saying "Peak Virtual Memory : 395 MB" please see the attached print-screen of an error.
as this is std. reference design why this error generate..?
regards
kaushal
I think there was a thread on this forum a little while ago about compiling the udp offload example on a more modern version of Quartus. You should try a search on the forum.
--- Quote Start ---
--- Quote End ---
Hello There,
One Unique problem i have seen in this error , as i change the quartus version from 9.0 to 9.1 and 11.0 the requirement of Peak virtual memory increase.
as in Q9.0 it says "Peak virtual memory: 395MB"
as in Q9.1 it says "Peak virtual memory: 407MB"
as in Q11.0 it says "Peak virtual memory:540 MB"
(attached print screen of all three quartus version's)
i have gone through the thread related to same issue, but don't find any clue though i have valid license for all above quartus version's.
http://www.alteraforum.com/forum/showthread.php?t=19377
kaushal
The real error message isn't the peak memory line (which is just an information) but the first one, about the empty clock collection. It seems that the clock name in line 39 of the test_project_top.sdc file is wrong.
Hello Daixiwen,
if i set test_project_top.v (top level design file without making it symbol file) as a top level entity then compile the project there is no problem ....but it generate .sof only.....
kaushal
