Hi all,
I am using quartus 11 and nios ide eclipse on a linux platform but I cannot build any project. Each time I get the message: 'Cannot run program "make": Unknown reason.' Does anyone knows what this is related to? I launched quartus in administrator mode but it does not change anything. ThanksLink Copied
OK I solved the issue, it was due to the make program installation on my system. But still I cannot program my device through the usb-blaster with NIOS Eclipse. Although the FPGA on the DE1 board is programmed using the quartus programmer, the NIOS Eclipse program does not find it.
Did anyone here encountered such a problem on a linux system? Thanks.
