12603 Discussions
nios ii flash programmer
praveenkumar
can anyone tell me how i can know the  external flash is connected .
i added generic tristate controller and conduit bridge in qysys.
and assigned pins in pin planner .
i want to write to nor flash but  target is not connection
it is shwing "no nois 2 target is conncted or sof is not downloadded.but i did both 2 of them and i refreshed so many times.
can anyone tell me what i am doing wrong
EricMunYew_C_Intel
did you mean you can't write to the CFI flash? any log?
praveenkumar
we are using   micron parallel nor flash 256mb    Rc256p33tfe   with the cyclone iii device in active parallel mode
after  adding generic tri state controller and conduit bridge in qsys
by giving frin command line : nios2-flash-programmer  --base=0x01000000 --debug
its showing  like below no cfi table found
info: Mar 28, 2013 12:52:59 PM - (INFO) elf2flash: args = --input=E:/PCIE/NOR_FLASH/software/Hello/Hello.elf --output=E:/PCIE/NOR_FLASH/software/Hello_bsp/flash/Hello_cfi_flash_0.flash --boot=C:/altera/12.0/nios2eds/components/altera_nios2/boot_loader_cfi.srec --base=0x10000000 --end=0x20000000 --reset=0x10000000 --verbose
Info: Mar 28, 2013 12:52:59 PM - (FINE) elf2flash: Starting
Info: Mar 28, 2013 12:52:59 PM - (FINE) elf2flash: Done
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Reading System ID at address 0x20005008: verified
Info: no cfi table found at address 0x10000000
Info: Original contents (after writing 0xF0 and 0xFF00FF to address 0x10000000):
Info: 0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: Contents after writing 0x980098 to address 0x100000AA:
Info: Same after writing 0x980098 to address 0x10000154:
Info: Same after writing 0x00980098 to address 0x100002A8:
Info: Same after writing 0x980098 to address 0x10000055:
Info: Same after writing 0x980098 to address 0x100000AA:
Info: Same after writing 0x00980098 to address 0x10000154:
Info: Same after writing 0x980098 to address 0x100002A8:
Info: Same after writing 0x00980098 to address 0x10000550:
Info: 0: 89 00 01 00 89 00 04 00 04 D8 04 D8 04 D8 04 D8 ................
Info: 10: 51 00 59 00 00 00 01 00 00 00 00 00 20 00 95 00 Q.Y......... ...
Info: 20: 0A 00 00 00 02 00 00 00 01 00 0A 00 01 00 03 00 ................
Info: 30: 02 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF ................
Info: Ignored possible autoselect code 89-01 as no override data
Info: present in section [FLASH-89-01]
Info: Ignored possible autoselect code 0089-0001 as no override data
Info: present in section [FLASH-0089-0001]
Info: Ignored possible autoselect code 00010089-00040089 as no override data
Info: present in section [FLASH-00010089-00040089]
Info: leaving target processor paused
by reading through c code  by debugging
we got cfi information misssing at ox11 addresss  it had to be 0x52 but its showing ox5100.
even though i tried to  flash both sof and hex files from nois2flash prorammer gui
its showing
  error code8: programming file path --verbose
i find cfi table information is missing i tried to override my cfi flash by nios2override file by placing it in  path   nis2eds/bin
its showing
cfi erase region definitions dont match with device size
base address  not aligned in device  size (in my qsys address of generic controller is  0x01000000 )
how can i access the flash   because i have to load   (hex  or  flash file ) through uart  and i have to write in flash and run from memory.
EricMunYew_C_Intel
Can you check and refer to the attached.
praveenkumar
eah its the same way  i designed  in the qsys  and also   while  i writing to  flash  by following the datasheet procedure   .
ox4089  if i am writing this  16 bit  data in some 0x0 location
and while i am reading the location  0x0 its showing 0x89 and 0x1 location  its showing 0x40.
its showing lsb in 0x0 location and MSb in 0x1 location.
through code its reading  some cfi table locations according to datasheet.
so i think i correctley designed in qsys. and none of the above problems are solved .
and another question i converting .sof file to pof and i added cfi flash programmed through quartus programmer and it is stored in flash and application is running on power on. in same way if i convert the sof file to hex format and receive through uart and i will erase the flash and write the data in hex format manually through c code . will it run on power on condition
thaks for reply.
nome
Hello
Can we access or flashing Directly from FPGA if we doesn't  have CPLD in our Board?
praveenkumar
No,we didnt have cpld in our board ,we normally flashing through jtag in quartus  prorammer  by convertiong sof  to pof . it is running fine after power on . but in final level after system integration  it's not possible to flash using jatg .
so we have to download it through uart  by writing the file  flash manually from 0x20000 .
Is it workout .
and also problem with generic tristate conroller behaving like explained below
please answer these two questions.
praveenkumar
yeah we can   access  the flash through fpga without cpld  in quartus programmer and also with nios  ii flash programmer .after
compilation stage goto
programmer section and attach or add  your fpga device  and browse for .sof file  if u want to program to flash
right click on fpga  device  and u can find attach flash option .
u can choose which flash u used in your card .
and programm it.
nome
Hello
I am trying to configure EP2AGX Arria® II GX using EPM240 Max ii CPLD and on board having CFI Flash js28f256m29ewh
In my case our custom Board having Flash Address bus A0 to A24 bus and Data D0..D7 Bus connected with FPGA CEn, OEn,  WEn with FPGA
In case of cpld we have only Flash Address bus ,CEn and OEn, pins  WEn not connected with CPLD and also there is no data bus between cpld an flash
So That's why I am confuse how to program flash memory
Is it with from CPLD Or FPGA  because of Flash Data Bus only connected with FPGA configure data 8 bit port like DATA0 to DATA7
That s why I asked you
In your Above case I think its Big Endian and Little endian Issue I did this issued in PIc32 MPU
Thanks for your Reply knowledgeable
Nome
praveenkumar
hi nome ,
In ur board there is no  flash data  bus  lines  connected to ur P2AGX Arria® II GX   or  EPM240 Max ii CPLD.
CFI Flash js28f256m29ewh for this flash   if  there is no data lines   u cannot use it  .
its like waste piece in board.
nome
Hello praveenkumar
As above I told Data Bus only connected with  FPGA  EP2AGX Arria® II GX
No Data Bus connected with CPLD even no WEn pin connected with CPLD
So That's why I am confuse how to program flash memory by CPLD OR FPGA
Nome
praveenkumar
No Data Bus connected with CPLD even no WEn pin connected with CPLD .
 the u can program it with ur fpga only.
i dont know why  u r using cpld .  there is no option for loading through jtag.
u can program ur flash by using fpga .
nome
Hello
Thanks for your reply
True But Flash address bus  A0 to A24 is connected With CPLD CEn and OEn, pins and also
One 12 bit Data Bus connected between CPLD and FPGA
My question is If we want to use Cpld as a flash programming  first Load SOF in Fpga to connected Flash Data Bus to CPLD data Bus also WEn pins
Maybe CPLD  will work as a flash Programing
What would you say ?
Nome
praveenkumar
hi ,
good to hear that but  u r  flash is 12 bit data bus or other .
and also have u ever tried to access the flash with  nios ii  software  or some other programming .
in my project there is an issue which i mentioned above .
try to reply to my email :
praveentatikonda2155@gmail.com
EricMunYew_C_Intel
Have you tried to program your flash using Quartus Programmer and PFL.
You can refer to below for PFL IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
praveenkumar
yeah i tried with pfl ,
actually  i initilized onchip memory with hex file and i genreted the sof file .
and that sof file is  converted into pof file .
that is wroking fine  on power on .it s stored in the flash .
but when i add tristate controller and conduit bridge   its not working .i tried all  the methods explained in edhandbook.
when i add sof and hex file separately to  generate the pof  and i programmed its not working.
i want to know the pof file content and when converted to .hexout  there is  so much  data  .i want to know the addresss in which that data of pof  is storing in cfi flash locations.
