Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
nios2_51 : Driver compilation problem
Hi
We have migrated from nios2 => nios2_51 and I am trying to compile with nios2_51 an old driver which has already been compiled under nios2.
I have warnings when I compile it and the insmod is refused on the target.
On the board I have the following message :
GXEOE: Unknown symbol memcpy
JGXEOE: Unknown symbol memset
JGXEOE: Unknown symbol __up
JGXEOE: Unknown symbol __down_interruptible
insmod: cannot insert `/home/JGXEOE.o': Unknown symbol in module (-1): No such file or directory
When compiling with a makefile as recommended on the mail (Post# 20 May 2 2005 by Jwistead) i have the following warnings in verbose mode V=1
Building modules, stage 2.
make -rR -f /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/scr
ipts/Makefile.modpost
scripts/mod/modpost -i /cygdrive/c/altera/kits/nios2_51/bin/eclipse/workspace/kernel_stm1_ed3/build/Module.symvers v
mlinux /cygdrive/m/huon3_hds_esoe_dev_7570r1_01_ln/hds_esoe/Stm1oE/Test/jgxeoe_driver/JGXEOE.o
*** Warning: "__up" [/cygdrive/m/huon3_hds_esoe_dev_7570r1_01_ln/hds_esoe/Stm1oE/Test/jgxeoe_driver/JGXEOE.ko] undefined
*** Warning: "__down_interruptible" [/cygdrive/m/huon3_hds_esoe_dev_7570r1_01_ln/hds_esoe/Stm1oE/Test/jgxeoe_driver/JGXE
OE.ko] undefined!
*** Warning: "memset" [/cygdrive/m/huon3_hds_esoe_dev_7570r1_01_ln/hds_esoe/Stm1oE/Test/jgxeoe_driver/JGXEOE.ko] undefined!
*** Warning: "memcpy" [/cygdrive/m/huon3_hds_esoe_dev_7570r1_01_ln/hds_esoe/Stm1oE/Test/jgxeoe_driver/JGXEOE.ko] undefined!
In the vmlinux.map of my kernel memcpy and memset are present !
I don't understand why the symbols are no more found.
I seems that the folders are not exactly the same between nios2 and nios2_51
Has somebody the same trouble ?
Thank you
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif rv
