nios2-download Verify Failed
Thanks in advance.
We are finally getting a chance to migrate to the mmu branch. Our goal is to use the TSE and Marvell. We've seen in the wiki that we will need to do some adds to the *.dts, etc.
This is a joint effort so I haven't done all the environment setup myself. I see we are using the "trunk" branch when I do a "git branch -l" on both "uClinux-dist" and "linux-2.6.x"
I'm using the Cyclone III 3c120 Evaluation Board
We got a good *.sopcinfo file and *.sof
We successfully got a *.dts file using the Wiki pages and we built an image.
In the "make menuconfig" we selected "dts" and set the path.
WE've Tried VARIOUS things for the DTB at physical address - which from what
I found should be used and 0xC0000000
But we still get the same Verify Failed error on nios2-download and it always starts
loading at the 0xC0000000
Altera Nios2 Command Shell [GCC 3]
Version 10.1, Built Tue Nov 30 02:10:00 PST 2010
[NiosII EDS]$ nios2-download -g linux.initramfs.gz
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 4912KB in 84.6s (58.0KB/s)
Verifying C0000000 ( 0%)
Verify failed between address 0xC0000000 and 0xC000FFFF
Leaving target processor paused
/cygdrive/c/altera/10.1/quartus/qdesigns/Work/Cyclone3c120/cycloneIII_3c120_nios
II_standardMMU/uClinux
[NiosII EDS]$
What are we missing? I feel very close. Do we need to modify something in the *.dts?
You have to set the "Memory base address" to the address of your main RAM, not including the MMU kernel area offset (0xC0000000). For example, I have 0x04000000 for DDR.
For the simple case -- you should uncheck "DTB at physical address" and instead check "Compile and link device tree into kernel image" and put the path to your DTS file there.
The fancier alternative, which I haven't tried --
IF you are:
  • building your device tree into your FPGA image (onchip ROM)
  • OR loading it through u-boot
  • OR storing it in flash
you need to compile your DTS (source) to a DTB (binary) manually (I don't know the tool/command) and use the latter. Uncheck "Compile and link device tree into kernel image". Check "DTB at physical address" and put in the address of the onchip ROM or flash or wherever u-boot puts the DTB in RAM.
If this clarifies it for you, please add the missing information to the wiki pages you used.
Thanks. I'll let you know how it goes. That will be next week sometime.
TO_BE_DONE
O.K. Got it to load at 0xD0000000
In make menuconfig I needed - in Processor type and features:
(0x10000000) Link address offset for booting
Hangs when booting so now time to check the hardware design.
That's not right -- that's the value you should put in "Memory base address". The "Link address offset for booting" is an *offset* in your RAM, so it needs to be smaller than the size of your RAM. It's where the image gets loaded before bing uncompressed into the beginning of RAM, so memory size minus approximate size of image minus some leg room gets you a reasonable offset. 2/3 the size of your RAM is also a good rule of thumb.
The download should then start at kernel virtual offset + "Memory base address" + "Link address offset for booting". So in your case, something like 0xD2000000.
Thanks for explaining that. I will try (probably this weekend) and post.
I'm having the very same problem. How does one set the memory base address?
--- Quote Start ---
--- Quote End ---
I see this as the first option under "Platform options"
Thanks in Advance.
I had to leave this and work on another project. Now that I'm back to it I decided to to use the example from the website for the 3C120 Eval board. So I'm starting with that sopc to create the *.dts and then *.dtb and with the *.dtb the zImage.
I'm doing what is says on the Altera Wiki Devicetree and clarified by ykozlov and the zImage downloads but I still hang at boot.
When I make the *.dts I get the following messages:
Waring decriptor memory connected through a bridge. I'll probably mess things up trying to gues what memory I'm connected to...
Component pll_master of class dummy_master is unknown
but I do get my *.dts.
Originally I DID miss the big step of manually getting a *.dtb from the *.dts.
With the non mmu I used to build the zImage and download with nios2-download -g and then use the nios2-terminal.
So, the only way I can get it to load and verified is by having the link address offset = 0x12000000 – and the DTB can be anything.
But the nios2-terminal hangs.
