Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
nios2-elf-objcopy?
Hi All,
In the Nios I , generally using the nios-elf-objcopy to convert an srec to binay raw file, and i see the Starter sign
"Nios" , this file is downloaded and copied in memory by my bootloader,
well in the nios2, i do the same thing but i dont found any sign ( "N2") but if i launch directly the srec work
have any suggestion?
Thank's
