nios2 eval license
Hi - I'm trying to use the Quartus web edition tool to download the Nios2
and Triple speed ethernet eval cores. When I visit the link that
I'm directed to for Opencores:
<link deleted - per forum rules>
There is no obvious Opencores "hook". Then, going into the online
IP selector, then following the NIOS II link, it takes me here:
Which again offers no "eval" license downloads. So I'm to the point
that I figure I'm wasting my time (time == money), so after some
searching, I see I can just buy the licenses (triple speed enet, sdram,
nios2) for $995 IPS-EMBEDDED. Visiting Digikey, they don't know the part
number as described. Then, Newark/Arrow both show "out of stock", with
10 day or more lead time. Maybe I'm spoiled by Amazon, but is it truly
the case that Altera is making this so hard intentionally?
Note, I did start this journey via the Megacore Wizard, which offers "download core"
in NIOS2, but just takes me to the first link above..
I could buy the cores separately off Digikey, but again, no stock, 3-10 day lead time.
I feel like I accidentally stepped into a time portal which took me clear back to
the 1980s, before online commerce!
Suggestions?
you should be able to evaluate the Nios and TSE core without purchasing a license at all. can simulate, run the FPGA tethered indefinitely, or run untethered for an hour
once it comes down to actually buying the IP Suite, a vendor should be able to process it in a day or two and send you a code so you can generate a license
Thanks. What makes the problem a bit odd is that the other megafunctions in the
library seem to instance properly. It's just some of the cores that are "core" (pun
intended) to implementing a NIOS2 design on a BeMicro or DE0-Nano design
seem to be a harder to re-download.
I believe the problem I'm running into - which is adding an accelator to the BeMicroSDK
design - is probably due to an "old" NIOS2 license hiding somewhere in my design
folders. Had hoped to just re-download a fresh time-limited license to clear
things out :)
in Tools > License Setup you can take a look at what licenses Quartus can see
