nios2 gsl linking problem
hello
i am using Nios II EDS 11.1 and i want to use gsl for some processing. i had done all of steps for introducing gsl include path to eclipse. gsl is built with nios ii gcc. and i wrote the blew code:
#include <stdio.h>#include <gsl/gsl_sf_bessel.h> int main() { printf("Hello from Nios II!\n"); double x=5.0; double y=gsl_sf_bessel_J0(x); return 0; }
and i recieve the below error on console:
**** Build of configuration Nios II for project gslt1 **** make all Info: Building ../gslt1_bsp/ make --no-print-directory -C ../gslt1_bsp/ Info: Compiling hello_world.c to obj/default/hello_world.o nios2-elf-gcc -xc -MP -MMD -c -I../gslt1_bsp//HAL/inc -I../gslt1_bsp/ -I../gslt1_bsp//drivers/inc -IC:\altera\11.1\quartus\bin\cygwin\usr\local\include -IC:\altera\11.1\quartus\bin\cygwin\usr\local\include\gsl -DSYSTEM_BUS_WIDTH=32 -pipe -D__hal__ -DALT_NO_INSTRUCTION_EMULATION -DALT_SINGLE_THREADED -O0 -g -Wall -EL -mno-hw-div -mhw-mul -mno-hw-mulx -o obj/default/hello_world.o hello_world.c hello_world.c: In function 'main': hello_world.c:23: warning: unused variable 'y' Info: Linking gslt1.elf nios2-elf-g++ -u close -T'../gslt1_bsp//linker.x' -msys-crt0='../gslt1_bsp//obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../gslt1_bsp/ -LC:\altera\11.1\quartus\bin\cygwin\usr\local\lib -Wl,-Map=gslt1.map -O0 -g -Wall -EL -mno-hw-div -mhw-mul -mno-hw-mulx -o gslt1.elf obj/default/hello_world.o -lm -lgsl -lgslcblas obj/default/hello_world.o: In function `main': E:\DE2-115\DE2_115_demonstrations\DE2_115_Audio\software\gslt1/hello_world.c:23: undefined reference to `gsl_sf_bessel_J0' collect2: ld returned 1 exit status make: *** Error 1
please help me.
thank you
I'd check that the library (libgsl.a ?) actually contains the required symbol.
thank you for your response, yes this is true, but in linking session this error occurred.what can i do with this problem?
It is also possible that the linker is finding a different copy of the library - the -L parameters set the search path.
An alternative is to explicitly specify path/libfoo.a (or libfoo.so) on the linker command line instead of -lfoo. Removing the vaguaries of the search path.
Not sure whether the IDE will let you do that though.
