Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
nios2 problem
While I am building a system with multiple clock domains based on the Alter document following error displayed at the time geneartion.
2005.08.02 15:22:22 (*) Running Generator Program for cpu
eperl: SOPC_KIT_NIOS2 environment variable not set
Error: Generator program
for module 'cpu' did NOT run successfully.
generator cmd was '/tools/altera/quartus5/linux/perl561/bin/perl -I/tools/altera/quartus5/sopc_builder/bin -I/tools/altera/quartus5/sopc_builder/bin/europa -I/tools/altera/quartus5/sopc_builder/bin/perl_lib -I/local/linux/lib/perl5/5.6.1/i686-linux -I/local/linux/lib/perl5/5.6.1 -I/local/linux/lib/perl5/site_perl/5.6.1/i686-linux -I/local/linux/lib/perl5/site_perl/5.6.1 -I/local/linux/lib/perl5/site_perl -I. -I/tools/altera/kits/nios2/components/altera_nios2 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es -I/tools/altera/kits/nios2/components/altera_nios_custom_instr_endian_converter -I/tools/altera/kits/nios2/components/amd_avalon_am29lv128m_flash -I/tools/altera/kits/nios2/components/altera_nios_dev_kit_stratix_edition_sram -I/tools/altera/kits/nios2/components/amd_avalon_am29lv065d_flash -I/tools/altera/quartus5/sopc_builder/components/altera_sopc_builder -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s40 -I/tools/altera/kits/nios2/components/altera_nios2 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_cyclone_2c35 -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_clock_adapter -I/tools/altera/kits/nios2/components/altera_avalon_spi -I/tools/altera/kits/nios2/components/altera_avalon_cfi_flash -I/tools/altera/kits/nios2/components/altera_avalon_dma -I/tools/altera/kits/nios2/components/altera_avalon_mailbox -I/tools/altera/quartus5/sopc_builder/components/altera_ahb_avalon_bridge -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_avalon_ahb_bridge -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_tri_state_bridge
-I/tools/altera/kits/nios2/components/altera_nios_eval_board_cyclone_1c12 -I/tools/altera/kits/nios2/components/altera_avalon_lan91c111 -I/tools/altera/kits/nios2/components/altera_avalon_lcd_16207 -I/tools/altera/kits/nios2/components/altera_nios_dev_kit_stratix_edition_sram2 -I/tools/altera/kits/nios2/components/altera_avalon_cf -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_burst_adapter -I/tools/altera/kits/nios2/components/altera_nios_multiply -I/tools/altera/kits/nios2/components/altera_nios_dev_board_cyclone_1c20 -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_user_defined_interface -I/tools/altera/kits/nios2/components/altera_avalon_cy7c1380_ssram -I/tools/altera/kits/nios2/components/altera_plugs_library -I/tools/altera/kits/nios2/components/altera_avalon_cs8900 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10 -I/tools/altera/kits/nios2/components/altera_avalon_jtag_uart -I/tools/altera/kits/nios2/components/altera_avalon_asmi -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_onchip_memory -I/tools/altera/kits/nios2/components/altera_avalon_onchip_memory2 -I/tools/altera/kits/nios2/components/altera_avalon_timer -I/tools/altera/kits/nios2/components/altera_avalon_new_sdram_controller -I/tools/altera/kits/nios2/components/altera_nios_custom_instr_bitswap -I/tools/altera/kits/nios2/components/altera_avalon_epcs_flash_controller -I/tools/altera/kits/nios2/components/altera_avalon_performance_counter -I/tools/altera/kits/nios2/components/altera_avalon_sysid -I/tools/altera/kits/nios2/components/altera_avalon_mutex -I/tools/altera/kits/nios2/components/altera_avalon_uart -I/tools/altera/kits/nios2/components/altera_nios_custom_instruction -I/tools/altera/kits/nios2/components/altera_user_board_setup -I/tools/altera/kits/nios2/components/altera_avalon_pio /tools/altera/kits/nios2/components/altera_nios2/cpu_core_select.pl --system_name=std_1c20 --target_module_name=cpu --system_directory=/research/najeeb/standard --sopc_directory=/tools/altera/quartus5/sopc_builder --sopc_lib_path=/research/najeeb/standard+/tools/altera/kits/nios2/components+/tools/altera/quartus5/sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=/tools/altera/kits/nios2/components/altera_nios2 --sopc_quartus_dir=/tools/altera/quartus5 --projectname=standard.quartus '
Error in processing. System NOT successfully generated.
My directory structure is /tools/altera/quartus5 and nios2 is in /tools/altera/kits
Operating system is redhat 7.3
Path variables given in bash_profile are given below
PATH=$PATH:/tools/altera/quartus5/bin
export QUARTUS_ROOTDIR=/tools/altera/quartus5
export SOPC_BUILDER_PATH=/tools/altera/kits/nios2
export niosbin=/tools/altera/kits/nios2/bin
export niosgnu=/tools/altera/kits/nios2/bin/nios-gnupro/bin
Can any one help me to reolve this problem.
Thanking You in advance
Junaid.k
Highlighted
On the Linux platform, I would recommend starting everything from within an SDK shell. In that way, you don't have to worry about any environment variables, other than the license server.
In your particular case, you missed the SOPC_KIT_NIOS2 environment variable.
- slacker
