yesterday while digging around with some options in my nios II project I found out that setting the buffer of the JTAG UART component to the maximum value possible would lead to a segmentation fault when I try to execute nios2-terminal, just setting that value back to minimum and everything runs smooth. It might be a bug in the nios2-terminal implementation that can't allocate enough memory to deal with the big buffer of JTAG? Thanks, Lucas.Link Copied
