Oh on fire, who can help me, man?
this is the boot info below,in my custom Cyclone II board for nios2, I thought I have meet a ghost. [NiosII EDS]$ nios2-download -g zImage Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 570KB in 13.1s (43.5KB/s) Verified OK Starting processor at address 0x02500000 /cygdrive/d/..../image [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Uncompressing Linux... Ok, booting the kernel. I did not know whether I got the success to boot the kernel. Because I have cut off the network module. How do I to debug the kernel when it start , any advice? any tools ?any recommended? are OK.Many thanks for the cool man.Link Copied
- « Previous
- 1
- 2
- Next »
I suspected that I compile the kernel on the vmware 7.1.1 with Ubuntu 10.04 LTS. Also, I tried the nios2 tar 20100621,20090929,20080619 using the default setting. All reports are like this problem.
Does anyone compile it in the vmware?- Mark as New
--- Quote Start --- I suspected that I compile the kernel on the vmware 7.1.1 with Ubuntu 10.04 LTS. Also, I tried the nios2 tar 20100621,20090929,20080619 using the default setting. All reports are like this problem. Does anyone compile it in the vmware? --- Quote End --- Have you find any solution to solve this problems? Can sharing the solution and thankss very much!!
- « Previous
- 1
- 2
- Next »
