Hi I am implementing opencoreI2C, can some one double check my code. I am new to opencoreso I am having problems in figuring out scl and sda.
Here is my code # include <stdio.h># include "alt_types.h"# include "opencores_i2c_regs.h"# include "opencores_i2c.h" int main() { /* IOWR_OPENCORES_I2C_CTR(0x0, 0xA); /* turn off the core*/ //IORD_OPENCORES_I2C_CTR(0x0); /* turn off the core*/ /* printf("IORD: %x",IORD_OPENCORES_I2C_CTR(0x0)); return 0; } */# define I2C_BASE 0x0# define clk ALT_CPU_FREQ# define speed 100000 //I2C_init(alt_u32 base, alt_u32 clk, alt_u32 speed); // ++++++++++++++++++++++++ initialize ++++++++++++++++++++++++++++++++++++ //IOWR_OPENCORES_I2C_CTR(I2C_BASE,0); // turn off the core //int i = 100; //while (i!=0){ //printf("CTR %x at base %x \n",IORD_OPENCORES_I2C_CTR(I2C_BASE),I2C_BASE); //--i; //}# define I2C_DEBUG //int I2C_init(alt_u32 base,alt_u32 clk, alt_u32 speed) //int I2C_start(alt_u32 base, alt_u32 add, alt_u32 write); //alt_u32 I2C_read(alt_u32 base); //int I2C_write(alt_u32 base, alt_u8 data); //int I2C_stop(alt_u32 base); /* these functions are polled only. */ /* all functions wait until the I2C is done before exiting */ /**************************************************************** int I2C_init This function inititlizes the prescalor for the scl and then enables the core. This must be run before any other i2c code is executed inputs base = the base address of the component clk = freuqency of the clock driving this component ( in Hz) speed = SCL speed ie 100K, 400K ... (in Hz) 15-OCT-07 initial release *****************************************************************/ IOWR_OPENCORES_I2C_CR(I2C_BASE, OPENCORES_I2C_CR_IACK_MSK); // clearn any pening IRQ IOWR_OPENCORES_I2C_PRERLO(I2C_BASE,0x31); // load low presacle bit IOWR_OPENCORES_I2C_PRERHI(I2C_BASE,0x00); // load upper prescale bit IOWR_OPENCORES_I2C_CTR(I2C_BASE,0x80); // turn on the core printf("CTR %x \n",IORD_OPENCORES_I2C_CTR(I2C_BASE)); //++++++++++++++++++++++++ send slave address and verify ++++++++++++++++++ IOWR_OPENCORES_I2C_TXR (I2C_BASE, 0x3A); IOWR_OPENCORES_I2C_CR(I2C_BASE, 0x90); while( IORD_OPENCORES_I2C_SR(I2C_BASE) & OPENCORES_I2C_SR_TIP_MSK) {printf( "TIP 1\n"); //while(( IORD_OPENCORES_I2C_SR(I2C_BASE) & 0x02) == 0x02) //{printf( "TIP 1 & SR = %x \n",IORD_OPENCORES_I2C_SR(I2C_BASE));} printf( "SR = %x \n",IORD_OPENCORES_I2C_SR(I2C_BASE)); while((IORD_OPENCORES_I2C_SR(I2C_BASE) & 0x80) == 0x80) {printf("NO ACK 1\n"); IOWR_OPENCORES_I2C_TXR (I2C_BASE, 0x3A); IOWR_OPENCORES_I2C_CR(I2C_BASE, 0x80); while(( IORD_OPENCORES_I2C_SR(I2C_BASE) & 0x02) == 0x02) printf( "TIP 1 & SR = %x \n",IORD_OPENCORES_I2C_SR(I2C_BASE)); printf("hi"); //else //++++++++++++++ send slave register address to be read from ++++++++++ printf("ACK 1\n"); printf( "SR = %x \n",IORD_OPENCORES_I2C_SR(I2C_BASE)); IOWR_OPENCORES_I2C_TXR(I2C_BASE, 0x00); IOWR_OPENCORES_I2C_CR(I2C_BASE, 0x90); while( (IORD_OPENCORES_I2C_SR(I2C_BASE) & 0x02) == 0x02 ) {printf( "TIP 2 \n");} if((IORD_OPENCORES_I2C_SR(I2C_BASE) & 0x80) == 0x80) printf("\t NO ACK 2\n"); else{ IOWR_OPENCORES_I2C_TXR(I2C_BASE, 0x3B); IOWR_OPENCORES_I2C_CR(I2C_BASE, 0x90); {printf( "TIP 3 \n");} if((IORD_OPENCORES_I2C_SR(I2C_BASE) & 0x80) == 0x80) printf("\t NO ACK 3\n"); else{ alt_u32 x = IORD_OPENCORES_I2C_RXR(I2C_BASE); printf("Received Byte %x \n",x); IOWR_OPENCORES_I2C_CR(I2C_BASE, 0x08); IOWR_OPENCORES_I2C_CR(I2C_BASE, 0x08); IOWR_OPENCORES_I2C_CTR(I2C_BASE,0x00); } } } return 0; } }Link Copied
