Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
pio drive
hi all,
does any one have a project(C code) which enable to drive PIO of 1s40 board (sevenseg, lcd, led pio)
I used the count_binary example of altera, in nios II IDE it works very well.
but when I create a nios2 linux project it won't compile
I think I have problems with Makefile
please help me
Highlighted
Re: pio drive
there is the problem I got : http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
make -k all  no emulation specific options. make: *** No rule to make target `alt_irq.h&#39;, needed by `count_binary.o&#39;. make: *** No rule to make target `io.h&#39;, needed by `count_binary.o&#39;. make: *** No rule to make target `alt_types.h&#39;, needed by `count_binary.o&#39;. make: *** No rule to make target `altera_avalon_pio_regs.h&#39;, needed by `count_binary.o&#39;. make: *** No rule to make target `nios2.h&#39;, needed by `count_binary.o&#39;. make: *** No rule to make target `system.h&#39;, needed by `count_binary.o&#39;. make: Target `all&#39; not remade because of errors
Highlighted
Re: pio drive
Hi sdhnain,
--- Quote Start ---
originally posted by sdhnain@May 9 2006, 05:03 PM
there is the problem i got :  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
make -k all  no emulation specific options. make: *** no rule to make target `alt_irq.h&#39;, needed by `count_binary.o&#39;. make: *** no rule to make target `io.h&#39;, needed by `count_binary.o&#39;. make: *** no rule to make target `alt_types.h&#39;, needed by `count_binary.o&#39;. make: *** no rule to make target `altera_avalon_pio_regs.h&#39;, needed by `count_binary.o&#39;. make: *** no rule to make target `nios2.h&#39;, needed by `count_binary.o&#39;. make: *** no rule to make target `system.h&#39;, needed by `count_binary.o&#39;. make: target `all&#39; not remade because of errors
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15229)</div>
--- Quote End ---
Please post your Makefile.
Highlighted
Re: pio drive
--- Quote Start ---
originally posted by sdhnain@May 9 2006, 10:51 PM
hi all,
does any one have a project(c code) which enable to drive pio of 1s40 board (sevenseg, lcd, led pio)
i used the count_binary example of altera, in nios ii ide it works very well.
but when i create a nios2 linux project it won&#39;t compile
i think i have problems with makefile
please help me
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15227)
--- quote end ---
--- Quote End ---
You can&#39;t use HAL api in uClinux.
Look at the sample pio driver in arch/nios2nommu/kernel/pio.c
Highlighted
Re: pio drive
thanks hippo,
the pio.c is good, but it drives only LEDs and seven seg, I need also LCD.
is it possible ?
Highlighted
Re: pio drive
--- Quote Start ---
originally posted by sdhnain@May 10 2006, 04:52 PM
thanks hippo,
the pio.c is good, but it drives only leds and seven seg, i need also lcd.
is it possible ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15250)
--- quote end ---
--- Quote End ---
There is no LCD driver for nios2 dev board.
You will have to write or port one.
Highlighted
Re: pio drive
--- Quote Start ---
originally posted by hippo+may 10 2006, 05:28 am--><div class='quotetop'>quote (hippo @ may 10 2006, 05:28 am)</div>
--- quote start ---
<!--quotebegin-sdhnain@May 10 2006, 04:52 PM
thanks hippo,
is it possible ?
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15252)</div>
[/b]
--- Quote End ---
Hippo,
Is there any pointer to what should look at to write a LCd application for NIOS ii uclinux ?
Highlighted
Re: pio drive
hi all, i&#39;m also trying to control the lcd module using c program. pls guide. thx.
