12434 Discussions
please help me . cygpath: can't convert empty path
**** Build of configuration Default for project mynios_ch395 ****
make all
系统找不到指定的路径。
系统找不到指定的路径。
Info: Building ../mynios_ch395_bsp/
make --no-print-directory -C ../mynios_ch395_bsp/
process_begin: CreateProcess(NULL, pwd, ...) failed.
make[1]: *** No rule to make target `/system.h', needed by `all'. Stop.
make: *** [../mynios_ch395_bsp/-recurs-make-lib] Error 2
**** Build Finished ****
do i need to install MinGW and Msys? how to ?
You only get the necessary definitions if you run your build in the Nios II command shell. This is in the windows start menu.
