hello
how to make postbuild actions in niosii ide (v5.1). i just want to make ihex after each build. i'm using auto makefile. thank youLink Copied
I dont knw how to do it in IDE.
But you can use nios2-elf-objcopy, add to your Makefilenios2-elf-objcopy -O ihex vmlinux vmlinux.hex
--- Quote Start --- originally posted by hippo@Feb 10 2006, 04:00 PM i dont knw how to do it in ide.
but you can use nios2-elf-objcopy, add to your makefile
nios2-elf-objcopy -o ihex vmlinux vmlinux.hex
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12673)</div> --- Quote End --- i know how to make hex file with nios2-elf-objcopy and elf2hex but we are using a autogenerated make file, thats generated each time priror build by IDE. do you know where makefile's teplates are placed?
Try right-click on the project, select "Properties", then "Builders". Click the "New" button to generate a builder. You can specify an executable, probably a batch file as well. When you build the project Eclipse will launch the "Builders" in sequence.
Hope that helps, Andrew
