I am running on the Altera 1c20 devlopment board using the factory configuration. I understand from previous postings that I need to locate the kernel at 0000 0000 in FLASH in order for it to boot when the reset button is pressed. s this correct? What do I need to modify in the kernel project to relocate the binary file to 0000 0000? Thanks for your time, ShlomoLink Copied
